[QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Christina.Ratcliff at csiro.au Christina.Ratcliff at csiro.au
Thu Mar 7 18:06:55 PST 2019
Hi Nathan,
I’ve just checked and still can’t see it.  I also removed the html for the about tab as well and that hasn’t worked either.
I have noticed that for other plugins version tab shows External dependencies is None, and Experimental is either Yes or No. ( ie https://plugins.qgis.org/plugins/processing_r/version/1.0.5/)
For PAT External dependencies is  Yes and Experimental is blank.
Could this be the issue?
Cheers,
Christina
From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
Sent: Friday, 8 March 2019 11:58 AM
To: Ratcliff, Christina (A&F, Waite Campus) <Christina.Ratcliff at csiro.au>
Cc: QGIS Developer <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Hey  Christina,
Yeah, it's a bit odd it's not showing up at all in the XML output.  I wonder if it was the HTML in the changelog as I can't see anything else that is different.  I have edit the changelog and removed the HTML to see if that picks it up.
Edited the changelog on this version for now to test that theory: https://plugins.qgis.org/plugins/pat/version/0.1.0/
On Fri, Mar 8, 2019 at 11:11 AM <Christina.Ratcliff at csiro.au<mailto:Christina.Ratcliff at csiro.au>> wrote:
Hi QGIS Developers,
I’m  following up on this issue which I posted last month. While it triggered  a lot of discussion I never received a firm answer as to whether my PAT plugin could be hosted and made discoverable as a QGIS plugin on the official plugins site.
About a week ago I uploaded a new version of PAT for some bug fixes, and it remains unapproved. Is this likely to get approved so users can find and install it via the plugin manager?
I was interested to see that PAT v0.1.0 has now had 131 downloads directly from the QGIS repository so there is definitely an interest.  Currently version 0.1.0 is showing on the website as being approved, but when I search for it in using the QGIS plugin manager, I can’t find it, even with the experimental option ticked on. Is there a reason for this?
Kind Regards,
Christina
PLEASE NOTE: The information contained in this email may be confidential or privileged. Any unauthorised use or disclosure is prohibited. If you have received this email in error, please delete it immediately and notify the sender by return email. Thank you. To the extent permitted by law, CSIRO does not represent, warrant and/or guarantee that the integrity of this communication has been maintained or that the communication is free of errors, virus, interception or interference.
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190308/f9d19fa0/attachment.html>
More information about the QGIS-Developer mailing list
