[QGIS-Developer] Red '__MACOSX' in plugin layer list
Thomas Baumann
rdbath.regiodata at gmail.com
Tue Mar 12 07:53:10 PDT 2019
Hi Richard,
yes for QGIS3 the OSMDownloader is one of the plugins with macosx folder:
check for QGIS 3.4:
MapsPrinter.0.5.zip
AzimuthDistanceCalculator.2.0.zip
OSMDownloader.1.0.zip
MongoConnector.1.2.0.zip
Socrata.2.0.zip
natusferaqgis3.1.0.zip
FS3.1.0.1.zip
geohey_toolbox.0.4.zip
qgisgbifapi.0.3.0.zip
HotspotAnalysis.1.0.2.zip
SleuthInputs.3.0.zip
ecovaluator.2.0.zip
Hqgis.0.4.1.zip
I adapted my script so it works for walking through the filesystem instead
of crawling through the parsed repository xml:
It walks recursive through your main repository folder and checks each zip
file for the macosx folder:
https://gist.github.com/rdbath/7f617d4d3b3417fdb50ae9048e2056cc
Listing the emails of the authors is something I can't do at the moment as
they are not part of the repository xml, so I have no access to the email
adresses.
I guess it's better to directly contact the authors instead of opening one
issue for each plugin, especially as a part of the tracker-url's in the
repository is not up to date.
I will write a seperate email about this topic in a second.
regards,
Thomas
Am Di., 12. März 2019 um 10:23 Uhr schrieb Richard Duivenvoorde <
rdmailings at duif.net>:
> On 12/03/2019 09.21, Thomas Baumann wrote:
> > In order to cause less traffic and have a better performance it would be
> > much better to run the script on the server where the plugin zipfiles
> > are located.
> Hi Thomas,
> If you provide me the script I will run it.
> With me the OSMDownlader plugin added it. You can see it by going into
> the folder on your disk. The folder contains all kind of file data (not
> sure if it sensitive or not).
> I created an issue:
> https://github.com/qgis/QGIS-Django/issues/62
> Maybe you can upload your script there?
> ANd maybe a feature request :-)
> Also list the email of the author so we can mass mail the current
> __MACOSX uploaders :-)
> Thanks for idea and work
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190312/e9793fbe/attachment-0001.html>
