[QGIS-Developer] Red '__MACOSX' in plugin layer list
Paolo Cavallini cavallini at faunalia.it
Tue Mar 12 08:08:18 PDT 2019
In analigy with the other email, I would suggest to forget about 2.18,
and check only 3.*. I will deal with the list of plugins below.
Thanks.
On 12/03/19 15:53, Thomas Baumann wrote:
> Hi Richard,
> yes for QGIS3 the OSMDownloader is one of the plugins with macosx folder:
> check for QGIS 3.4:
> MapsPrinter.0.5.zip
> AzimuthDistanceCalculator.2.0.zip
> OSMDownloader.1.0.zip
> MongoConnector.1.2.0.zip
> Socrata.2.0.zip
> natusferaqgis3.1.0.zip
> FS3.1.0.1.zip
> geohey_toolbox.0.4.zip
> qgisgbifapi.0.3.0.zip
> HotspotAnalysis.1.0.2.zip
> SleuthInputs.3.0.zip
> ecovaluator.2.0.zip
> Hqgis.0.4.1.zip
> I adapted my script so it works for walking through the filesystem
> instead of crawling through the parsed repository xml:
> It walks recursive through your main repository folder and checks each
> zip file for the macosx folder:
> https://gist.github.com/rdbath/7f617d4d3b3417fdb50ae9048e2056cc
> Listing the emails of the authors is something I can't do at the moment
> as they are not part of the repository xml, so I have no access to the
> email adresses.
> I guess it's better to directly contact the authors instead of opening
> one issue for each plugin, especially as a part of the tracker-url's in
> the repository is not up to date.
> I will write a seperate email about this topic in a second.
> regards,
> Thomas
> Am Di., 12. März 2019 um 10:23 Uhr schrieb Richard Duivenvoorde
> <rdmailings at duif.net <mailto:rdmailings at duif.net>>:
>     On 12/03/2019 09.21, Thomas Baumann wrote:
>     > In order to cause less traffic and have a better performance it
>     would be
>     > much better to run the script on the server where the plugin zipfiles
>     > are located.
>     Hi Thomas,
>     If you provide me the script I will run it.
>     With me the OSMDownlader plugin added it. You can see it by going into
>     the folder on your disk. The folder contains all kind of file data (not
>     sure if it sensitive or not).
>     I created an issue:
>     https://github.com/qgis/QGIS-Django/issues/62
>     Maybe you can upload your script there?
>     ANd maybe a feature request :-)
>     Also list the email of the author so we can mass mail the current
>     __MACOSX uploaders :-)
>     Thanks for idea and work
>     Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
More information about the QGIS-Developer mailing list
