[QGIS-Developer] Red '__MACOSX' in plugin layer list
Paolo Cavallini cavallini at faunalia.it
Tue Mar 12 08:29:57 PDT 2019
Tickets opened on all 13 plugins.
Thanks again.
On 12/03/19 16:08, Paolo Cavallini wrote:
> In analigy with the other email, I would suggest to forget about 2.18,
> and check only 3.*. I will deal with the list of plugins below.
> Thanks.
> On 12/03/19 15:53, Thomas Baumann wrote:
>> Hi Richard,
>> yes for QGIS3 the OSMDownloader is one of the plugins with macosx folder:
>> check for QGIS 3.4:
>> MapsPrinter.0.5.zip
>> AzimuthDistanceCalculator.2.0.zip
>> OSMDownloader.1.0.zip
>> MongoConnector.1.2.0.zip
>> Socrata.2.0.zip
>> natusferaqgis3.1.0.zip
>> FS3.1.0.1.zip
>> geohey_toolbox.0.4.zip
>> qgisgbifapi.0.3.0.zip
>> HotspotAnalysis.1.0.2.zip
>> SleuthInputs.3.0.zip
>> ecovaluator.2.0.zip
>> Hqgis.0.4.1.zip
>> I adapted my script so it works for walking through the filesystem
>> instead of crawling through the parsed repository xml:
>> It walks recursive through your main repository folder and checks each
>> zip file for the macosx folder:
>> https://gist.github.com/rdbath/7f617d4d3b3417fdb50ae9048e2056cc
>> Listing the emails of the authors is something I can't do at the moment
>> as they are not part of the repository xml, so I have no access to the
>> email adresses.
>> I guess it's better to directly contact the authors instead of opening
>> one issue for each plugin, especially as a part of the tracker-url's in
>> the repository is not up to date.
>> I will write a seperate email about this topic in a second.
>> regards,
>> Thomas
>> Am Di., 12. März 2019 um 10:23 Uhr schrieb Richard Duivenvoorde
>> <rdmailings at duif.net <mailto:rdmailings at duif.net>>:
>>     On 12/03/2019 09.21, Thomas Baumann wrote:
>>     > In order to cause less traffic and have a better performance it
>>     would be
>>     > much better to run the script on the server where the plugin zipfiles
>>     > are located.
>>     Hi Thomas,
>>     If you provide me the script I will run it.
>>     With me the OSMDownlader plugin added it. You can see it by going into
>>     the folder on your disk. The folder contains all kind of file data (not
>>     sure if it sensitive or not).
>>     I created an issue:
>>     https://github.com/qgis/QGIS-Django/issues/62
>>     Maybe you can upload your script there?
>>     ANd maybe a feature request :-)
>>     Also list the email of the author so we can mass mail the current
>>     __MACOSX uploaders :-)
>>     Thanks for idea and work
>>     Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
More information about the QGIS-Developer mailing list
