[QGIS-Developer] loading images in QGIS Viewer with RPC modelisation
Julien Cabieces
julien.cabieces at oslandia.com
Wed Apr 15 23:57:27 PDT 2020
> Thanks for you answer.
> which version of QGIS do you use and how do you know that it's displayed according to RPC ?
I tested with development version [0] but I think it's already working
with previous one.
To check if it's displayed according to RPC, you could display
OpenStreetMap XYZ tiles beneath your image and check if your image is at
the right place.
The SCR (in QGIS right bottom corner) should default to 4326 and your
coordinate should be lat/long in degrees. If the RPC isn't read, you
should have coordinate in pixel instead.
[0] https://www.qgis.org/en/site/forusers/alldownloads.html#windows
Regards,
Julien
> Best Regards
> Laurène
> -----Message d'origine-----
> De : QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] De la part de Julien Cabieces
> Envoyé : mercredi 15 avril 2020 10:12
> À : qgis-developer at lists.osgeo.org
> Objet : Re: [QGIS-Developer] loading images in QGIS Viewer with RPC modelisation
> Hello,
> Last time I check, if the RPC file is in the same folder than your Pleiades image, QGIS will load it automatically when you open your Pleiades images. Your image will be displayed according to its RPC then.
> I think that Gdal (used by QGIS to open the file) looks for a file starting with RPC_
> Regards,
> Julien
>> Hello,
>> I would like to load an Satellite image from the sensor Pleiades in Qgis. Linked with the image there is an RPC (rational polynomial coefficient) file which give geolocation information.
>> I would like to load this image with the RPC information in the QGIS viewer.
>> Has someone already try to develop something about loading an image in QGIS viewer with RPC geolocation of any satellite sensor?
>> Best regards
>> Laurène Glandus
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
