[QGIS-Developer] stale bot :-(
Ian Turton ijturton at gmail.com
Tue Dec 22 06:51:38 PST 2020
That's odd to hear as I had one marked stale that had a PR attached
Ian
On Tue, 22 Dec 2020 at 10:03, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Richard,
> Sorry if it was a bit a rough start!
> The stale bot specifically picks only issues which are left with the
> "feedback" label.
> This was the case with these two issues. I notice Giovanni already fixed
> this.
> The assumption is that the veggies don't have open questions on them and
> this way we can filter the weed. Does that sound reasonable to you?
> Best regards
> Matthias
> On Tue, Dec 22, 2020 at 9:38 AM Richard Duivenvoorde <rdmailings at duif.net>
> wrote:
>> I received some "this issue will be closed because of lack of feedback",
>> but I think current 'stale bot implementation' is a little rude on the
>> edges.
>> (did I miss some discussion about this here?)
>> only because I commented on them. But some are just plain valid:
>> As an example:
>> https://github.com/qgis/QGIS/issues/39107#issuecomment-749298135
>> that is just a valid use-case (or maybe feature request?)
>> This one:
>> https://github.com/qgis/QGIS/issues/37984
>> is just valid (I even installed Oracle to check this...)
>> This one: also valid and still needed:
>> https://github.com/qgis/QGIS/issues/37956
>> Weeding the issues is not nice, so removing non-valid, old or non
>> responding is fine, but now I think the bot is pulling the veggies instead
>> of the weed :-)
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201222/69f5cf69/attachment-0001.html>
More information about the QGIS-Developer mailing list
