[QGIS-Developer] stale bot :-(
Matthias Kuhn
matthias at opengis.ch
Tue Dec 22 06:53:59 PST 2020
Hi Ian,
Can you share a link to this issue?
Thanks
Matthias
On Tue, Dec 22, 2020 at 3:51 PM Ian Turton <ijturton at gmail.com> wrote:
> That's odd to hear as I had one marked stale that had a PR attached
> Ian
> On Tue, 22 Dec 2020 at 10:03, Matthias Kuhn <matthias at opengis.ch> wrote:
>> Hi Richard,
>> Sorry if it was a bit a rough start!
>> The stale bot specifically picks only issues which are left with the
>> "feedback" label.
>> This was the case with these two issues. I notice Giovanni already fixed
>> this.
>> The assumption is that the veggies don't have open questions on them and
>> this way we can filter the weed. Does that sound reasonable to you?
>> Best regards
>> Matthias
>> On Tue, Dec 22, 2020 at 9:38 AM Richard Duivenvoorde <rdmailings at duif.net>
>> wrote:
>>> I received some "this issue will be closed because of lack of feedback",
>>> but I think current 'stale bot implementation' is a little rude on the
>>> edges.
>>> (did I miss some discussion about this here?)
>>> only because I commented on them. But some are just plain valid:
>>> As an example:
>>> https://github.com/qgis/QGIS/issues/39107#issuecomment-749298135
>>> that is just a valid use-case (or maybe feature request?)
>>> This one:
>>> https://github.com/qgis/QGIS/issues/37984
>>> is just valid (I even installed Oracle to check this...)
>>> This one: also valid and still needed:
>>> https://github.com/qgis/QGIS/issues/37956
>>> Weeding the issues is not nice, so removing non-valid, old or non
>>> responding is fine, but now I think the bot is pulling the veggies instead
>>> of the weed :-)
>>> Regards,
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201222/777f379a/attachment.html>
