[QGIS-Developer] stale bot :-(
Ian Turton ijturton at gmail.com
Tue Dec 22 06:59:17 PST 2020
Actually it was the PR itself that was closed -
https://github.com/qgis/QGIS/pull/39231
Ian
On Tue, 22 Dec 2020 at 14:54, Matthias Kuhn <matthias at opengis.ch> wrote:
> Hi Ian,
> Can you share a link to this issue?
> Thanks
> Matthias
> On Tue, Dec 22, 2020 at 3:51 PM Ian Turton <ijturton at gmail.com> wrote:
>> That's odd to hear as I had one marked stale that had a PR attached
>> Ian
>> On Tue, 22 Dec 2020 at 10:03, Matthias Kuhn <matthias at opengis.ch> wrote:
>>> Hi Richard,
>>> Sorry if it was a bit a rough start!
>>> The stale bot specifically picks only issues which are left with the
>>> "feedback" label.
>>> This was the case with these two issues. I notice Giovanni already fixed
>>> this.
>>> The assumption is that the veggies don't have open questions on them and
>>> this way we can filter the weed. Does that sound reasonable to you?
>>> Best regards
>>> Matthias
>>> On Tue, Dec 22, 2020 at 9:38 AM Richard Duivenvoorde <
>>> rdmailings at duif.net> wrote:
>>>> I received some "this issue will be closed because of lack of feedback",
>>>> but I think current 'stale bot implementation' is a little rude on the
>>>> edges.
>>>> (did I miss some discussion about this here?)
>>>> feedback", only because I commented on them. But some are just plain valid:
>>>> As an example:
>>>> https://github.com/qgis/QGIS/issues/39107#issuecomment-749298135
>>>> that is just a valid use-case (or maybe feature request?)
>>>> This one:
>>>> https://github.com/qgis/QGIS/issues/37984
>>>> is just valid (I even installed Oracle to check this...)
>>>> This one: also valid and still needed:
>>>> https://github.com/qgis/QGIS/issues/37956
>>>> Weeding the issues is not nice, so removing non-valid, old or non
>>>> responding is fine, but now I think the bot is pulling the veggies instead
>>>> of the weed :-)
>>>> Regards,
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Ian Turton
Ian Turton
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201222/56c1e703/attachment.html>
More information about the QGIS-Developer mailing list
