[QGIS-Developer] label: "backport release-3_16 BROKEN - YOU MUST DIY!!!"
DelazJ
delazj at gmail.com
Tue Dec 29 09:12:16 PST 2020
re,
replace link [0] with
https://github.com/qgis/QGIS/pulls?q=is%3Apr+%5BBackport+release-3_10%5D+is%3Aclosed
Le mar. 29 déc. 2020 à 18:10, DelazJ <delazj at gmail.com> a écrit :
> Hi,
> If I may, I still don't get the reason of the relabeling. With its current
> name it's no surprising that the action is broken, and we would never know
> whether it works if it's not renamed correctly. Also, I know I'm not a dev
> and I may miss some subtleties, but it's curious to have the same action
> properly work for 3.10 in qgis/QGIS repo [0], have it work in
> QGIS-Documentation repo [1] and being completely broken for 3.16 (using the
> same pattern)...
> [0]
> https://github.com/qgis/QGIS/pulls?q=is%3Apr+label%3A%22backport+release-3_10%22+is%3Aclosed
> [1]
> https://github.com/qgis/QGIS-Documentation/pulls?q=is%3Apr+label%3A%22backport+release_3.16%22+is%3Aclosed
> Regards,
> Harrissou
> Le mar. 29 déc. 2020 à 17:42, Alessandro Pasotti <apasotti at gmail.com> a
> écrit :
>> On Tue, Dec 29, 2020 at 5:36 PM Richard Duivenvoorde
>> <rdmailings at duif.net> wrote:
>> > Is this what the label says? :-) I'm hoping it is not, but...
>> Unfortunately it is: you must do it manually (cherry-pick).
>> Happy new year :)
>> > I have had some PR's for 3.17 of which are labeled such:
>> https://github.com/qgis/QGIS/pulls?q=is%3Apr+author%3A%40me+is%3Aclosed+label%3A%22backport+release-3_16+BROKEN+-+YOU+MUST+DIY%21%21%21%22
>> > Should I try to pull them all in 3.16?
>> > Regards,
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alessandro Pasotti
>> QCooperative: www.qcooperative.net
>> ItOpen: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20201229/d74b1957/attachment.html>
