[QGIS-Developer] Geopackage FID columns: i HATE them!!!!
Stephane Goldstein
s.n.g at gmx.com
Thu Mar 19 18:55:43 PDT 2020
I used to frequently get errors when copying and pasting features across
geopackage files.
So now, before saving the edited file, I select all features and set the
fid to NULL, which avoid errors most of the times.
On Fri, Mar 20, 2020 at 5:07 AM Alexis R.L. <alroyliz0 at gmail.com> wrote:
> Greetings,
> Personnally when splitting layers and when there are FID conflits, I try
> to solve it manually. Sometimes it tells me that the fid of feature x
> cannot be change, which are not indistinguishable.
> And the next time you open the geopackage there is a change that the fid
> column will now be the next column over and the initial fid column with bad
> fids is still there. If you had critical information in your second column
> too bad, its now a fid and you lost that information forever.
> Maybe that issue was fixed already since I'm mostly using 3.4.4 on my main
> setup as of now (waiting for some PRs to get merged before updating).
> Thanks
> Alex
> Le jeu. 19 mars 2020 à 02:04, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit :
>> Hi list,
>> Just wondering what everyone's thoughts are about geopackage FID
>> columns. Personally, I find them an absolute nightmare to deal with,
>> resulting in annoying (and dangerous) issues when trying to save
>> geopackage edits, such as
>> - field type issues: converting certain formats to geopackage fails,
>> because existing fields with name "fid" are of an incompatible type
>> with geopackage. Solution: manually uncheck the "fid" field from the
>> "save as" dialog.
>> - unique constraint violations: we've mostly fixed this in processing,
>> but it's still unfortunately really common to get failures when saving
>> edits to geopackage because some operation has resulted in duplicate
>> fids. This can be a nightmare to fix, if it's even possible to do so.
>> I personally HATE HATE HATE these columns, and would rather I never
>> saw them ever again. Does anyone else feel the same? If so, could we
>> potentially just permanently hide these columns from QGIS and avoid
>> all these dangerous issues for users?
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200320/3e7bfbfe/attachment-0001.html>
