[QGIS-Developer] gdal 3.1 in OSGeo4W/QGIS 3.14?
Régis Haubourg regis.haubourg at gmail.com
Tue May 26 09:36:55 PDT 2020
Le mar. 26 mai 2020 à 18:21, Jürgen E. Fischer <jef at norbit.de> a écrit :
> Hi,
> On Mon, 25. May 2020 at 17:34:14 +0300, Idan Miara wrote:
> > I can't find gdal 3.1 in OSGeo4W, but only gdal 3.04 and 3.2 (gdal-dev).
> > QGIS master depends on gdal-dev (3.2), but since QGIS 3.14 supposed to be
> > released in less then a month, won't it make sense to test it against
> gdal
> > 3.1 as gdal 3.2 won't be released before QGIS 3.14?
> And what about PROJ7?
> See also
> https://lists.osgeo.org/pipermail/qgis-developer/2020-February/060259.html
according to the bug tracker, the mentionned bug has been fixed.
@Nyall Dawson <nyall.dawson at gmail.com> do you know about any other blocker
on PROJ side that would justify to stick with 6.x versions in OSGEO4W?
Best regards
Régis
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> https://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200526/34a3eb21/attachment.html>
More information about the QGIS-Developer mailing list
