[QGIS-Developer] gdal 3.1 in OSGeo4W/QGIS 3.14?
Nyall Dawson nyall.dawson at gmail.com
Wed May 27 19:19:27 PDT 2020
On Wed, 27 May 2020 at 02:37, Régis Haubourg <regis.haubourg at gmail.com> wrote:
> Hi,
> Le mar. 26 mai 2020 à 18:21, Jürgen E. Fischer <jef at norbit.de> a écrit :
>> Hi,
>> On Mon, 25. May 2020 at 17:34:14 +0300, Idan Miara wrote:
>> > I can't find gdal 3.1 in OSGeo4W, but only gdal 3.04 and 3.2 (gdal-dev).
>> > QGIS master depends on gdal-dev (3.2), but since QGIS 3.14 supposed to be
>> > released in less then a month, won't it make sense to test it against gdal
>> > 3.1 as gdal 3.2 won't be released before QGIS 3.14?
>> And what about PROJ7?
>> See also https://lists.osgeo.org/pipermail/qgis-developer/2020-February/060259.html
> according to the bug tracker, the mentionned bug has been fixed.
> @Nyall Dawson do you know about any other blocker on PROJ side that would justify to stick with 6.x versions in OSGEO4W?
No blockers that I know of. I've been tracking proj/gdal master and I
think we should upgrade.
Nyall
More information about the QGIS-Developer mailing list
