[QGIS-Developer] py3_env in Windows installers
Jürgen E. Fischer
jef at norbit.de
Tue Sep 8 01:32:00 PDT 2020
Hi Richard,
On Tue, 08. Sep 2020 at 09:05:05 +0200, Richard Duivenvoorde wrote:
> If you start the osgeo4w command prompt, both in standalone and osgeo4w
> version, you have to run py3_env before being able to use (the QGIS used)
> python there (or am I wrong. I tested by running osgeo4w.bat within a 3.14
> standalone install)
> I know this was to be able to handle both py2 and py3, but I do not think we
> need to use python2 anymore is it?
py2 is still available in osgeo4w - although we don't use it anymore for QGIS.
> In that case I would propose to make py3_env part of the osgeo4w.bat file so
> we can instruct people to just go to the osgeo4w bat file to eventually pip
> install modules usable in QGIS?
You could also just move py3_env.bat to etc\ini\python3-core.bat and create an
empty py3_env.bat.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200908/59b284aa/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20200908/59b284aa/attachment.ksh>
