[QGIS-Developer] Disable/commenting provider filter?
Andreas Neumann
a.neumann at carto.net
Tue May 11 23:07:53 PDT 2021
Hi Richard and all,
Speaking of the little "Filter icon". Couldn't this icon be used to
toggle the filter state "on"/"off"?
A single click would toggle on/off state, a double click would open the
dialog?
Just an idea. Not sure if it is doable.
Thanks for working on this,
Andreas
On 2021-05-12 08:04, Richard Duivenvoorde wrote:
> On 5/11/21 10:45 PM, Jorge Gustavo Rocha wrote:
>> Hi,
>> Another workaround is layer duplication. You can have an instance
>> without filters and one with filters. Then switch between them.
>> But a filter history for the layer (like the one in the old DB manager
>> where you can save queries), could be useful.
> I'd probably go for the checkbox in the query dialog then. Clicking the
> little 'filter' icon in the layer manager will popup the query dialog.
> Duplicating a layer is an option, but messes up your project, if all
> you want to do is go over some specific ID's.
> A 'Recent' item IS available, so history IS available, it's just not
> convenient enough for me.
> Regards & thanks for input.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20210512/7861dc36/attachment.html>
