[QGIS-Developer] [Qgis-user] Questions of a newbie starting with QGIS Server
Aguilar Bolivar, Rosa (UT-ITC)
r.aguilar at utwente.nl
Thu Apr 21 00:46:43 PDT 2022
Hi, Harrisou
You could try the catalog (https://docs.qgis.org/3.22/en/docs/server_manual/catalog.html) to explore your projects.
I also used to the catalog to check the configuration of my projects, e.g., that the server had access to the sources (DB), etc.
Best regards,
Rosa
-----Original Message-----
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Richard Duivenvoorde via Qgis-user
Sent: Wednesday, April 20, 2022 8:24 PM
To: Harrissou s. <delazj at gmail.com>; qgis-user at lists.osgeo.org; qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-user] [QGIS-Developer] Questions of a newbie starting with QGIS Server
Hi Harrissou,
I think your pretty close :-)
Some remarks from the times I installed on Windows:
- I used a vanilla apache installer from https://www.apachelounge.com/
- indeed used the httpd.conf from osgeo4w to set all paths and env vars, VERY convenient
- are you sure the Qt vs qt is an issue? Thought Windows paths were not case sensitive?
The GDAL_DATA path you will need when you use for example the ECW or other drivers QGIS_AUTH_DB_DIR_PATH is maybe only needed when you have a project which uses authentication profiles? Others?
When you have a WMS/WFS server running normally you do not have a web app yet.
You either use the WMS of WFS as datasource in QGIS (or other clients) or you use OpenLayer/Leaflet to create an app in a browser using javascript.
Alessandro also created a landing page for WFS3/OGC API:
https://docs.qgis.org/3.22/en/docs/server_manual/services/ogcapif.html
but I found that sometimes tricky to setup...
Maybe others can share more info/experience
Regards,
On 4/20/22 18:58, Harrissou s. via QGIS-Developer wrote:
> Hi QGISers (sorry for cross-posting)
> I'm trying to setup a QGIS Server... on Windows and I'd like to share
> some suggestions/issues I faced in the process and ultimately ask for
> help on a bigger issue.
> I'm following the QGIS documentation instructions [0] and took the
> opportunity to update the docs[1][2], given that osgeo4w provides
> means to install apache. Review welcome, thanks.
> In the docs, it is suggested to add at the end of the httpd.conf file
> a set of variables. But I notice that *most* of them are already set
> in the httpd_qgis.conf file that is #included at the end of the
> httpd.conf file. I hence ignored the addition but, Questions:
> - are the GDAL_DATA and QGIS_AUTH_DB_DIR_PATH necessary for any purpose?
> - If so, for what? And is it possible (does it make sense) to add them
> to the httpd_qgis.conf file also?
> - Issue report: I think there is a typo in the httpd_qgis.conf file
> setting PATH and QT_PLUGIN_PATH. It mentions apps/qt5/ while it should
> be apps/Qt5/ (uppercase Q).
> In my process, I didn't set the gdal or db paths above, I fixed the
> uppercase typo and when I tested I could get a reply for
> GetCapabilities as in the docs. Using the QGIS training project, I could do a GetMap which successfully returned my map canvas image. Good! My server is OP!
> Well, this is where I got lost. I thought the request would output in
> the browser some image i could zoom in, pan, maybe identify... But NO,
> I got a plain, static image. What am I supposed to do next? How can I
> make my project queryable, zoomable, pannable, anythingable... in a web browser?
> I might have overlooked, but the docs does not seem t provide any
> information for newbies like me, for the next step. Where should I
> look now? Your help to get out of this trouble would be much appreciated. Thanks.
> Regards,
> Harrissou
> [0]
> https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html#
> installation-on-windows
> <https://docs.qgis.org/3.22/en/docs/server_manual/getting_started.html
> #installation-on-windows>
> [1] reading:
> https://github.com/DelazJ/QGIS-Documentation/blob/installQGISServerWin
> dows/docs/server_manual/getting_started.rst
> <https://github.com/DelazJ/QGIS-Documentation/blob/installQGISServerWi
> ndows/docs/server_manual/getting_started.rst>
> [2] pull-request: https://github.com/qgis/QGIS-Documentation/pull/7508
> <https://github.com/qgis/QGIS-Documentation/pull/7508>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Qgis-user mailing list
Qgis-user at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
