[QGIS-Developer] Problems configuring the statusBar
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Mon Dec 12 00:19:36 PST 2022
Hi AF,
you can always query objects for their type with type(objectname) or
even access their documentation in an interactive interpreter session
with help(objectname). Then you know what methods and attributes they
expose or which Qt documentation page is matching whatever object you
are handling.
Be aware that pages like https://doc.qt.io/qt-5/qstatusbar.html only
list the "direct" members and that the objects might have already
inherited others. For that you can click the "List of all members,
including inherited members" link.
CaSe matters! Best use an IDE that helps you with autocompletion and
inspection, this helps a lot when learning. For PyCharm all you need to
do is select the python-qgis.bat file as interpreter and let it scan the
Python modules for a while.
When googling for QGIS Python classes, make sure you are reading
up-to-date documentation matching your QGIS version, e. g.
https://qgis.org/pyqgis/3.28/gui/QgisInterface.html
Cheers, Hannes
Am 12.12.22 um 01:42 schrieb afernandez via QGIS-Developer:
> Hi Nyall,
> Obviously I'm not an expert in Qt/QGIS (only been using it for a few
> weeks) and still have many things to learn. Most of the code works
> fine (by staying away from very complex structures) and styling
> widgets has been no problem until now when trying to do anything with
> the statusBar. From your comment, I went back to the
> PyQGISDeveloperCookbook(v3.22) and snippets like
> myicon =
> QIcon("/home/ubuntu/.local/share/QGIS/QGIS3/profiles/default/python/plugins/app/appicon.png")
> iface.mainWindow().setWindowIcon(myicon)
> iface.mainWindow().setWindowTitle("Tailoring QGIS")
> had worked in the past. One problem has been to find specific
> documentation about iface.mainWindow().statusBar(), let alone examples
> and those online (e.g.
> https://gis.stackexchange.com/questions/210327/how-to-display-qgis-processing-bar-from-a-plugin)
> kind of suggests that my initial snippet could work. I'll continue
> reading the cookbook tomorrow but, in the meantime, is there any other
> documentation discussing iface in general or
> iface.mainWindow().statusBar() that I should also be reading? (Note: I
> also checked https://doc.qt.io/qt-5/qstatusbar.html)
> Thanks,
> AF
> P.S. Again sorry about the extra messages that shouldn't have been
> sent to the thread (hopefully it won't happen again)
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Where2B Konferenz 2022
15. Dezember 2022 in Bonn und Online
https://where2b-conference.com/
WhereGroup GmbH
Grevenweg 89
20537 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221212/db5b7080/attachment.htm>
