[QGIS-Developer] Time for db manager to become an "opt-in" plugin?
José de Paula Rodrigues
espinafre at gmail.com
Sun Jul 10 06:06:21 PDT 2022
Hi, all,
I must say I agree with Alexandre; one of the most precious feature of QGIS
for me and the folks that work with me is the ability to very quickly and
easily interact with PostGIS, making experiments, testing a query,
adjusting, tailoring, comparing with other kinds of data sets, right there
on the QGIS interface. I also agree that QGIS is not a database
"manager"/"workshop"/"weaver" tool, so tasks such as creating database
models, adding or removing columns, creating or droping
tables/schemas/databases/roles might be out of scope for QGIS.
If the leaders really think the DB Manager plugin should go away, perhaps
the current functionality of the SQL Window from DB Manager (with the
ability to create a layer right from the query) could be moved to something
akin to the current Python console.
One of the greatest strengths of QGIS, compared to the proprietary industry
leader, is the ease and immediacy of working with all kinds of different
dataset types, and I feel that if the DB manager goes away without some
sort of replacement for its query window, this QGIS advantage will shrink a
little.
Thank you all.
On Sun, Jul 10, 2022 at 8:51 AM Alexandre Neto via QGIS-Developer <
qgis-developer at lists.osgeo.org> wrote:
> Hi Richard
> A domingo, 10/07/2022, 08:56, Richard Duivenvoorde via QGIS-Developer <
> qgis-developer at lists.osgeo.org> escreveu:
>> On 7/10/22 03:02, Alexandre Neto via QGIS-Developer wrote:
>> > This db manager functionality is unique, and is (in my opinion) one of
>> the reasons why QGIS is PostGIS de facto client.
>> Hi Alexandre,
>> My de facto client is DBeaver, a cross platform FOSS general Database
>> client (written in Java).
> I know dbeaver and like it alot and I use it too, but IMHO sending people
> to another software is not a solution.
> It even has a simple spatial viewer (as: show geometries on OSM, both for
>> Postgis and Geopackages) in the data tabs.
>> (in my setup I have Mysql(spatial), Postgis, Geopackages and Oracle
>> connections in one set)
>> Changing constraints/permissions/edits in data etc etc is really 'simple'
>> (as in via gui).
> This is what I use dbeaver for, and as I said before that is not my main
> concern.
>> So running a spatial analysis to me is:
>> - run a query in a <project>.sql file, create a view or temporary table
>> for it
>> - load it in QGIS
>> (- saving all queries including comments in that sql file)
> Now this is where I think the workflow is incomparable. In QGIS you can
> overlap and see several results at the same time. something that it's not
> possible to do in dbeaver (or pgadmin). You can easily change your query
> and reload again in a very easy and fast way. Creating views or temporary
> tables in dbeaver to go and open it in QGIS, then if something went off go
> back to dveaver do it again... Nah... :-p
>> Would that be a work around for you?
>> It is like: A DB client like DBeaver should not try to be a (Q)GIS....
>> and vice versa ;-)
> I agree! My worries are not power users like you and me, we can use
> several software at the same time without crossing the wires, But it's damn
> hard to make common GIS folks transition to spatial databases and spatial
> SQL. Although Alessandro brilliant work will help this transition, the SQL
> editor from dbmanager was by far the best tool for spatial SQL.
> This being said, I understand that db manager will eventually die anyway
> for lack of maintenance if nothing is done otherwise. I just ask for some
> time so we have a plan for making sure that important functionality is not
> delegated to third party plugins.
> Maybe I should lead a QEP followed by a crowd funding? If that is the
> issue.
> "We" added lots of new functionality to QGIS, some of which I probably
> won't ever use, I am ok with it, but it's hard to see functionality I use
> everyday go away.
> Thanks,
> Alexandre
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
... et cognoscetis veritatem et veritas liberabit vos.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20220710/1a325725/attachment.htm>
