[QGIS-Developer] Question about proj data files in the QGIS application folder
Andreas Neumann
a.neumann at carto.net
Tue Nov 8 01:52:03 PST 2022
Hi Luca,
There are certain files in this share/proj folder that you should not
delete, because otherwise QGIS would behave strange:
- copyright_and_licenses.csv (not sure if it s necessary)
- deformation_model.schema.json
- other.extra
- proj.db
- proj.ini
- projjson.schema.json
- README.DATA
- triangulation.schema.json
- world
I also always delete all the other grid shift files that I don't need.
It is getting a bit overwhelming with all these files (that you never
need).
Greetings,
Andreas
On 2022-11-08 10:05, Johannes Kröger via QGIS-Developer wrote:
> Only if your users use transformations where certain CRSs in those
> areas might be involved. If you are definitely not going to use local
> CRSs in e. g. Germany or the US, you can remove those TIFs. If your
> users attempt to use those CRS, they will receive a fairly descriptive
> error message about certain files missing their installation so it
> should be easy to fix.
> Cheers, Hannes
> Am 08.11.22 um 09:33 schrieb Luca Manganelli via QGIS-Developer:
>> Hello,
>> I am preparing the QGIS Windows package file (it's a zip file) for
>> distribution in our organization (we don't use MSI).
>> I noticed that the folder /share/proj contains TIF files and it weighs
>> 584 MB, are they necessary for the working of the QGIS?
>> Thank you and have a nice day
>> Luca
>> Comune di Trento
>> via Belenzani, 19 - 38122 Trento | C.F e P. IVA: 00355870221
>> tel. +39 0461.884111 | www.comune.trento.it [1]
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Johannes Kröger / GIS-Entwickler/-Berater
> Where2B Konferenz 2022
> 15. Dezember 2022 in Bonn und Online
> https://where2b-conference.com/
> WhereGroup GmbH
> Grevenweg 89
> 20537 Hamburg
> Germany
> Tel: +49 (0)228 / 90 90 38 - 36
> Fax: +49 (0)228 / 90 90 38 - 11
> johannes.kroeger at wheregroup.com
> www.wheregroup.com [2]
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
Links:
[1] http://www.comune.trento.it
[2] http://www.wheregroup.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221108/772dd9ac/attachment.htm>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221108/772dd9ac/attachment.gif>
