[QGIS-Developer] QGIS Plugin crash
Alexandre Neto
senhor.neto at gmail.com
Wed Nov 23 06:00:41 PST 2022
Hello Jose,
Your English sounded quite good to me :)
This is the repository where you should report these bugs to the plugin
authors:
https://github.com/geomatico/qgis-sigpac/issues
Best regards,
Alexandre Neto
Jose Antonio Fernandez Martin via QGIS-Developer <
qgis-developer at lists.osgeo.org> escreveu no dia quarta, 23/11/2022 à(s)
11:52:
> Hello everyone,
> my name is Jose and I have just suscribed to this mailing list. Apologies
> if my English is not very accurate, as I don't practice it very often here
> in Spain :-)
> My organization is having problems when using QGIS 3.14.15 with the
> "SIGPAC downloader" plugin. And I haven't found any bug tracker for that
> specific plugin so according to the QGIS Plugin page I should report the
> problem on this list. Upgrading to QGIS 3.22 doesn't solve the problem.
> The first issue comes when the plugin is installed. An error says "The
> plugin 'sigpac_downloader' could not be loaded because an error ocurred
> when calling the classFactory method" (translated from my spanish version
> of QGIS)
> The full error trace is provided in the attached document
> "SIGPACDownloader_install.txt"
> However there is apparently one workaround to that issue, you just have to
> select "reinstall" plugin and it finishes ok. After re-entering QGIS, the
> plugin is loaded and the menu entry appears in the "plugins" menu entry.
> But the real problem comes when trying to use the plugin: The SIGPAC
> Downloader window opens and says you have to accept the Terms Of Use. When
> clicking on the proper button, a new window opens with blank content
> (nothing is loaded) and after a few seconds the QGIS "Unexpected Error"
> window appears suggesting to report the crash and quit the program. The
> crash report is enclosed in this email as "stack.txt"
> Some relevant information about our QGIS settings: An HTTP Proxy is used
> for web connections, so the server, port, username and password are set in
> order to access the plugin repository.
> Looking forward to read from you.
> Kid regards,
> Jose.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20221123/03ad8c72/attachment.htm>
