[QGIS-Developer] Re-add Georeferencer action to raster menu?
Raymond Nijssen
r.nijssen at terglobo.nl
Tue Sep 27 03:00:54 PDT 2022
Hi Nyall,
I remember getting confused too. When searching for it, the things I
tried were typing "georef" in the locator bar, in the processing toolbox
(filter) and in the plugin manager. Not finding anything anywhere there.
Maybe it would be possible to make that work?
For example all the menu items showing up in the locator?
Kind regards,
Raymond
On 27-09-2022 08:40, Nyall Dawson via QGIS-Developer wrote:
> Hi devs!
> I'm after some wider feedback -- in 3.26 I moved the "Georeferencer"
> action from the Raster menu to the "Layers" menu, as the georeferencer
> was expanded to support more than just raster layers and it no longer
> seemed a logical place to put this action.
> But we've seen a lot of confusion and bug reports about the missing
> action since this move.
> I'm pondering whether we should add a second shortcut to the
> georeferncer back into the Raster menu, so that this tool will be
> available through either location.
> Is this a good idea and helps avoid user confusion? Or a bad one which
> causes more UI bloat?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
