[QGIS-Developer] [Qgis-psc] [Qgis-community-team] QGIS webserver size vs publishing old docs
Johannes Kröger (WhereGroup)
johannes.kroeger at wheregroup.com
Tue Mar 21 07:50:37 PDT 2023
Thank you!
I am also in Den Bosch and so I would love to join the discussion there,
hopefully with valuable contributions and solutions :))
Cheers, Hannes
Am 21.03.23 um 09:48 schrieb DelazJ via QGIS-Developer:
> Hi,
> Thanks all for the feedback
> I second the (somewhat reformulated by myself) opinion that we
> shouldn't just buy space or disk because we would be financially able
> to do so. Not sure it is a sustainable behavior and we'd just be
> postponing the issue (remember, pyqgis repo is also concerned). We
> rather should identify what we do really want/need to provide to our
> community. So I'm glad you'll discuss this at Den Bosch./(and I keep
> updating my list of todo for the sys admin)/
> I also second the suggestion to delete 2.8 and 2.14. It'd release
> enough space to serve 3.28.
> About the questions:
> Hannes, the folders are so big because they serve (in about 15 to 20
> languages):
> - the HTML files (the ones we all know)
> - the PDF files (e.g. https://docs.qgis.org/3.22/pdf/)
> - and the zipped HTML files (https://docs.qgis.org/3.22/zip/) for
> local use for people that do not have full access to WEB but not sure
> if anyone is using them. It could be interesting to know stats of
> downloads (if any).
> About why 3.10 is bigger than 3.22, it had two languages we no longer
> publish, and looks like we managed somehow to provide smaller files
> (plugins and third-party providers chapters that were removed on the
> road? 🤔)
> Bernd, sorry for the old docs popping up during search. Unfortunately,
> not something new [0], and we still are looking for people with
> knowledge in this area to help us improve the situation. What I
> usually do is to replace the version number in the URL and most of the
> times, it work well unless the file has been restructured.
> The line that shows the top message is at [1]. If someone knows how we
> can add the section anchor to that URL, suggestions are more than welcome.
> [0] https://github.com/qgis/QGIS-Documentation/issues/6449 and there
> might be older discussion in ML
> [1]
> https://github.com/qgis/QGIS-Documentation/blob/master/themes/rtd_qgis/layout.html#L14
> Greetings,
> Harrissou
> Le lun. 20 mars 2023 à 21:51, Andreas Neumann via QGIS-PSC
> <qgis-psc at lists.osgeo.org> a écrit :
> Hi,
> Thank you for checking, Richard - yes an additional 35 € per month
> for just 80gb more is not nothing ... compared to a root server.
> Ok - let's delete the 2.8 and 2.14 releases. I think it would be
> good to keep the latest 2.x (2.18) around. This should give us
> some initial room to serve the current documentation. If we need
> additional space. we could also remove the 3.10 documentation.
> And yes, it is a good idea to discuss infrastructure tasks and
> responsibilities in Den Bosch!
> I hope that Kartoza can soon find a good sysadmin person - now
> that the idea to employ a Sysadmin and the funds had been approved.
> Andreas
> On Mon, 20 Mar 2023 at 21:39, Richard Duivenvoorde
> <rdmailings at duif.net> wrote:
> On 3/20/23 17:31, Andreas Neumann wrote:
> > Hi Matthias,
> > Sure - buying more space is an option. I would like to get
> an idea - however - what the monthly expected costs are. Is
> this a "virtual" server at Hetzner? How much disk space does
> it have currently, how much do we want? What is the price
> difference?
> Building is done on a real Hetzner server: qgis6.org
> <http://qgis6.org> a Hetzner EX42 Root server about 50euro/month
> Serving the site + docs is done on www2.qgis.org
> <http://www2.qgis.org> a Hetzner Cloud cpx31 160GB disk
> 14euro/ month (as cloud would be cheaper etc etc)
> We can upgrade the www2 to a newer bigger CLOUD server, but
> that is about 35 euro/month for just 80Gb more..
> Probably then it is better to leave the cloud, and just add an
> extra root server on which you have a couple of terrabytes...
> for 50 euro/month
> Can we sit together in Den Bosch and do decide something on
> this? I really feel unhappy if people telling us "why is there
> even a need to care": we/I am not a sysadmin, so everybody
> with great knowledge and idea's: please help out!
> > At some point - cleanup of old stuff just makes sense.
> Getting rid of version 2.14 and 3.8 (it probable should mean
> 3.8 and not 2.8 - right) would make sense. Documentation
> always focuses on LTR versions, so all the "in-between"
> versions that are older than 3-4 years could be deleted.
> >> # du -hs *
> >> 255M doc-test
> >> 579M QGIS-Documentation
> >> 7.2G QGIS-Documentation-2.14
> >> 6.3G QGIS-Documentation-2.18
> >> 7.7G QGIS-Documentation-2.8
> >> 12G QGIS-Documentation-3.10
> >> 11G QGIS-Documentation-3.16
> >> 9.4G QGIS-Documentation-3.22
> >> 579M QGIS-Documentation-3.28
> >> 8.0G QGIS-Documentation-3.4
> >> 31G QGIS-tests
> >> 16G QGIS-Website
> We still have version 2 (TWO) .8 .14 and .18 around :-) so it
> NOT a typo...
> So: can I delete those?
> And also 3.10 (as this is a 2018 release)
> The QGIS-tests dir, contains the info available at:
> http://test.qgis.org
> BUT!!! that url/dns actually still points to the old server
> (qgis2)
> That site hosts the ogcapif / wfs / wms tests (untill 26th of
> januari)???
> Anybody feeling need or responsible for this?
> We are not serving (yet) test.qgis.org <http://test.qgis.org>
> from www2 ...
> Regards,
> Richard
> Andreas Neumann
> QGIS.ORG <http://QGIS.ORG> board member (treasurer)
> QGIS-PSC mailing list
> QGIS-PSC at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei derwww.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20230321/be5470d6/attachment.htm>
