[QGIS-Developer] How does QGIS parses the shapefile so quickly (? ??)
Colin Sare-Soar colin.saresoar at terrashape.co.uk
Mon Mar 27 20:38:06 PDT 2023
I can't say why QGIS handles Shapefiles so quickly but I do have experience of reading and writing them for myself.
I didn't want to use Shapelib - too big and cumbersome so I just added read/write functions to my application and used the ESRI document for reference. It is quite easy to follow but you have to be careful with the endian-ness of the different fields.
Just search for 'ESRI Shapefile format' and you should find their document.
> On 28/03/2023 02:00 +07 qgis-developer-request at lists.osgeo.org wrote:
> Send QGIS-Developer mailing list submissions to
> 	qgis-developer at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	https://lists.osgeo.org/mailman/listinfo/qgis-developer
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	qgis-developer-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of QGIS-Developer digest..."
> Today's Topics:
>    1. How does QGIS parses the shapefile so quickly (? ??)
>    2. Re: How does QGIS parses the shapefile so quickly
>       (Alessandro Pasotti)
>    3. Re: How does QGIS parses the shapefile so quickly (Even Rouault)
>    4. Re: How does QGIS parses the shapefile so quickly (Werner Macho)
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dear All,
>   Sorry to interrupt, I'm newer to QGIS, whe I use QIGS, I find that it is so quick for QGIS to parse shapefile even it is a very big file, I try to decode the file by my own with shapelib library, but the result is disappointed, I try to learn it by myself with QGIS source code but failed, so anyone can help point the entry of  decoding process?
> Thanks.Hi,
> QGIS is using the GDAL/OGR library to read the shapefiles.
> On Mon, Mar 27, 2023 at 9:51 AM 余 绍健 via QGIS-Developer
> <qgis-developer at lists.osgeo.org> wrote:
> > Dear All,
> > Thanks.
> Alessandro Pasotti
> QCooperative:  www.qcooperative.net
> ItOpen:   www.itopen.it
> Le 27/03/2023 à 10:06, Alessandro Pasotti via QGIS-Developer a écrit :
> > Hi,
> which uses shapelib
> >> Dear All,
> >> Thanks.
> http://www.spatialys.com
> My software is free, but my time generally not.
> Hi!
> Just to add some side information regarding Shapefiles:
> (ignore it if understanding shapefiles ist a must in your case)
> http://switchfromshapefile.org/
> regards
> Werner
> On Mon, Mar 27, 2023 at 5:16 PM Even Rouault via QGIS-Developer <qgis-developer at lists.osgeo.org> wrote:
> > > Hi,
> > which uses shapelib
> > >> Dear All,
> > >> Thanks.
More information about the QGIS-Developer mailing list
