[QGIS-Developer] Best practices for storing plugin settings
Johannes Kröger (WhereGroup) johannes.kroeger at wheregroup.com
Fri Oct 20 07:05:25 PDT 2023
Hi Gabriel,
there are no fixed standards but it might be a great project to evaluate
the plugin landscape and see how people do it in the wild, to see if
there are some defacto standards or best practises.
I tried to document some variations I found recently in
https://hannes.enjoys.it/blog/2023/07/plugins-in-qgis3-ini/
There should also be a post to a QGIS mailing list where I asked about
standards but I cannot find it again because mailing lists. Iirc the
answer was "there are no rules".
Cheers, Hannes
Am 16.10.23 um 04:01 schrieb Gabriel De Luca via QGIS-Developer:
> Hello everyone,
> I'm developing a plugin and I'm not sure where to write the settings.
> Should I create the settings object with my own organization and
> application? I would expect a plugin's settings to be stored in the
> profile folder where the plugin is installed, within the same qgis
> configurations file, so it doesn't seem like a good option to me.
> If I write the settings under the same organization and application as
> QGIS, is it appropriate to create a root group for my plugin? All the
> plugins I have installed did that, but for some reason they are hidden
> when viewing the advanced settings with the new tree widget.
> Is the "plugins" group appropriate to create a sub-group/key with the
> name of my plugin?
> The only email I found in the archive referring to the settings
> structure is [1], I'll keep it in mind when it comes to group/key
> names, but any other recommendations on good practices for third-party
> plugins are welcome.
> Regards,
> Gabriel
> [1]
> https://lists.osgeo.org/pipermail/qgis-developer/2017-March/047487.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Johannes Kröger / GIS-Entwickler/-Berater
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com
WhereGroup GmbH
c/o KK03 GmbH
Lange Reihe 29
20099 Hamburg
Germany
Tel: +49 (0)228 / 90 90 38 - 36
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the QGIS-Developer mailing list
