[QGIS-Developer] DefaultProxy and ambiguous wording in the options
Julien Cabieces
julien.cabieces at oslandia.com
Mon Mar 18 03:38:04 PDT 2024
I also stumbled on this particular matter in the past. If I remember correctly...
> Howdy!
> Before I make a tiny pull request I better ask:
> There has been confusion here because of the wording around the
> "DefaultProxy" and default proxy usage in Settings -> Options ->
> Network:
> - Under the checkboxed "Use Proxy for Web Access" section there is
> a combobox for the "Proxy type". The first entry is named
> "DefaultProxy", others are e.g. "HttpProxy" or "Socks5Proxy".
> - Next to the combobox is a text label saying "Default uses system's
> proxy". This label is always visible. Grey if the checkbox is not
> ticked, as normal text if it is ticked.
> There is some ambiguity with this:
> - By default the "Use Proxy for Web Access" checkbox is not ticked. So
> this could mean that by default the system's proxy is used, even if
> the checkbox is not ticked.
No, if the "Use Proxy for Web Access" is not ticked, there is "No Proxy"
at all
> - If the checkbox is ticked, then by default the first entry of the
> combobox is activated ("DefaultProxy"). Now it could be read that
> the default selection of the combobox, the "DefaultProxy", uses the
> system's proxy.
> - Last, and that is my understanding, "Default uses system's proxy"
> actually references the name of the "DefaultProxy" comboxbox option
> so if the user selects "DefaultProxy", then the system's proxy is
> used. (Same outcome as with the previous one but for a different
> reason).
Sorry, I don't get your point here, everything looks normal to me.
> I'd suggest using the actual full name of the combobox entry in the
> help text: "DefaultProxy uses the system's proxy".
> That would be a simple one-line diff in
> https://github.com/qgis/QGIS/blob/71583dbc0cd33d85d036bcccef5991bbd2e3b632/src/ui/qgsoptionsbase.ui#L5015
> It would be nicer to have a combobox entry like "DefaultProxy (uses
> system's proxy" in the combobox itself and drop the help text, but
> that would be more complex.
> The confusion was worse in a local environment because in the German
> translation the word "Default" was localized while the "DefaultProxy"
> combobox entry was not. :o)
I think that we get the translation directly from Qt Enum. That's why
someone just added the help text just besides the comboBox I think.
Why not having a tool tip instead of a help text just besides the
combobox ? or at least remove the help text when you don't select
"Default Proxy" ?
> Cheers, Hannes
Regards,
Julien
Julien Cabieces
Senior Developer at Oslandia
