[QGIS-Developer] SAGA GIS plugin maintenance
Stefano Campus
skampus at gmail.com
Thu May 21 05:15:58 PDT 2026
First of all, thank you all for your feedback.
It is clear that the problem is not (solely) the SAGA plugin, but rather a
perspective on the sustainability of open-source projects, which, I
imagine, Nyall has rightly raised.
To avoid any misunderstanding and in response to Greg’s comments, in this
context I am simply a user who used to use SAGA very frequently some time
ago; as the features of QGIS/ Processing have improved and expanded, I
hardly use it anymore, except for rasterisation, which allows complete
control over the rasterisation values when, for example, I have overlapping
points, and SAGA allows you to choose whether to assign the minimum,
average, maximum, sum, etc., to the raster cell – a function that GDAL does
not have.
However, I reiterate that I consider Nyall’s decision to be a ‘provocation’
(in a positive sense, let’s be clear) to draw attention to sustainability.
Jurgen has stated the difficulty in keeping up with SAGA’s developments,
which are often unannounced, and attempts at structured collaboration –
correct me if I’m wrong – with SAGA’s maintainers have not yielded good
results.
So, returning to the specific case, I believe the solutions could be:
1) SAGA is no longer a third-party module provider, as it no longer
develops or maintains any plugins;
2) specific voluntary contributions are found, either short-term or
long-term
tertium non datur!
Regards
s.
Il giorno gio 21 mag 2026 alle ore 13:41 Stefano Campus <skampus at gmail.com>
ha scritto:
> If I’m not mistaken, over the years, the SAGA maintainers haven’t paid
> much attention to integration with QGIS; proof of this is that they’ve
> changed the structure of the modules, renamed them, and so on, without
> making any announcement or contacting the QGIS maintainers in any way
> Il giorno gio 21 mag 2026 alle ore 11:53 <
> qgis-developer-request at lists.osgeo.org> ha scritto:
>> *Bas Couwenberg* sebastic at xs4all.nl
>> <qgis-developer%40lists.osgeo.org?Subject=Re%3A%20%5BQGIS-Developer%5D%20SAGA%20GIS%20plugin%20maintenance&In-Reply-To=%3Ce4d5973f-3ab3-4993-8e73-8e3a8a6ec88f%40xs4all.nl%3E>
>> *Thu May 21 03:40:36 PDT 2026*
>> - Previous message (by thread): [QGIS-Developer] SAGA GIS plugin
>> maintenance
>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/068253.html>
>> - *Messages sorted by:* [ date ]
>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/date.html#68254>
>> [ thread ]
>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/thread.html#68254>
>> [ subject ]
>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/subject.html#68254>
>> [ author ]
>> <https://lists.osgeo.org/pipermail/qgis-developer/2026-May/author.html#68254>
>> On 5/21/26 11:53 AM, Stefano Campus via QGIS-Developer wrote:
>> >* Do you think it would be a good idea to propose to the Steering Group that
>> *>* its maintenance be taken on directly by the QGIS.org Foundation and that a
>> *>* certain sum (1000–2000 euros?) be set aside in the annual budget for its
>> *>* maintenance?
>> No, I think it makes more sense for the SAGA developers to commit to maintaining the QGIS plugin which will likely motivate them to stabilize their interface.
>> Kind Regards,
>> Bas
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20260521/7f1ca5c7/attachment-0001.htm>
