[Qgis-psc] [Qt-for-Python] report of the technical group
    Marco Bernasocchi
    marco at qgis.org
    Mon Apr  4 01:02:42 PDT 2022
Hi Denis,
in the last PSC meeting we discussed this and agreed with your proposal.
Thanks a lot for taking care of this!
Cheers
Marco
On Wed, 2 Feb 2022 at 07:45, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> Dear PSC,
> Following the report of the evaluation of Qt-for-Python for QGIS' Python
> bindings and its conclusion [0], we proposed [1] to create a group of
> meaningful QGIS
> developers to propose some recommendations on what to do next.
> Alessandro, Julien, Matthias, Nyall and I met and the conclusions are the
> following:
> * we recognize Qt for Python as a valuable potential solution for QGIS’
> bindings
> * but we cannot take a formal final decision at this stage due to the
> remaining technical unknowns
> * the global amount of work required is considerable (50 to 100 days) and
> imprecise
> * we recommend to investigate more, proceed block by block and reevaluate
> at each step if we are still moving in the right direction
> * this procedure should be a grant for the project to avoid wasting money
> (e.g. deciding after 90% of the whole effort to finally stick to PyQt) and
> for the developers (workload estimation)
> * we recommend to use the 5000€ of development budgeted for 2022 for the
> next block to bring a broader set of tests in QGIS core running with PySide
> (under Qt6) so the group could meet again, reevaluate the decision and
> potentially propose a follow up
> * considering the short amount of time dedicated and the work already done
> by OPENGIS, it makes sense in terms of efficiency that OPENGIS also handles
> this block (other devs might get involved in the potential next ones)
> Hereby, we recommend the PSC to sponsor a follow-up on the investigation
> of using Qt-for-Python for QGIS’ bindings.
> For the technical group,
> Denis
> [0] https://github.com/qgis/QGIS-Enhancement-Proposals/issues/237
> [1] https://lists.osgeo.org/pipermail/qgis-psc/2021-November/009568.html
> Qgis-psc mailing list
> Qgis-psc at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/qgis-psc
Marco Bernasocchi
QGIS.org Chair
OPENGIS.ch CEO
http://berna.io
URL: <http://lists.osgeo.org/pipermail/qgis-psc/attachments/20220404/e4c295e0/attachment-0001.html>
More information about the Qgis-psc
