[Qgis-tr] linguist vs. transifex in GUI translation
Alexandre Neto
senhor.neto at gmail.com
Wed Apr 16 08:49:50 PDT 2014
Hi Werner and Richard,
I have just asked so I can inform the QGIS PT user group. The decision will
be made there.
I admit I'm a QtLinguist fan, because you can preview what you are
translating and you do it in a context. Anyway I believe (according to the
position of the people that already voted) that we (PT_pt) will use
transifex since it's more accessible to most users, and like you (Richard)
said most of the work is already "done".
Sorry Werner, I guess you will have to have more work with PT_pt by having
to download and integrate the tranlations in the source.
Sooner than later I will let you know what was our decision.
Best regards,
Alexandre Neto
On Wed, Apr 16, 2014 at 4:10 PM, Richard Duivenvoorde <richard at duif.net>wrote:
> On 04/16/2014 12:58 PM, Alexandre Neto wrote:
> > Hello Werner,
> > How many resource files will exist in transifex, only one? Will this
> > mean that the all translations in one language will be locked by a
> > single translator?
> Hi Alexandre,
> that depends on your workproces. There is just one ts file, so if you
> want to work with linguist, just work in the old way.
> But pt_PT is at >90% so I think it is usefull if you then work via
> Transifex: BUT using the web interface, NOT by downloading (and locking)
> the ts file.
> In that way you can work in parallel, as when you work via the
> webinterface, to my knowledge nothing is locked, you work string by
> string then.
> Only drawback for transifex I see now, is for new langauges because if
> you just start a translation, in transifex the strings are not grouped
> by sections like you see in linguist.
> But if you are (like PT) >90%, I think it is ok, you just search all
> changed or untranslated files easily.
> Regards,
> Qgis-tr mailing list
> Qgis-tr at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-tr
URL: <http://lists.osgeo.org/pipermail/qgis-tr/attachments/20140416/d7bdca34/attachment-0001.html>
More information about the Qgis-tr
