[Qgis-user] raster layer and vector layer ---> create 3D view from it
Larissa Junek
l.junek at gmx.net
Thu Feb 13 05:30:48 PST 2020
Hello Saber,
in the meantime I used New York 3D data to check out the 3D view tool.
Using the hints of your blog I'm having
* a Buildings_3D_Multipatch layer from a
DA10_3D_Buildings_Multipatch.gdb (vector layer)
* SRTM data N40W074.hgt (raster layer)
now.
Next steps:
* the srtm data in the 3D view tool: Type = DEM (raster layer) ,
Elevation = N40W074
* single symbol setting in the 3D view properties of
Using SRTM data this way doesn't help to depict the vectors in 3D (I
thought the srtm data have the function of a master). Do I have to
convert file formats?
I'm using QGIS 3.10.2 and win10.
Cheers, Larissa
-------- Weitergeleitete Nachricht --------
Betreff: Re: [Qgis-community-team] 3D view of LIDAR data city of boulder
Datum: Tue, 11 Feb 2020 17:22:32 +0100
Von: Larissa Junek <l.junek at gmx.net>
An: Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk>,
qgis-community-team at lists.osgeo.org
Hi Saber,
ok will the clipped Boulder data be suitable for the 3D dataset that we
want to provide in the qgis sample data?
I wonder if srtm data will have a good resolution. Will you also clip a
srtm dataset for usage in the qgis sample data?
Then I would of course prefer to use this data so that a user can
quickly check out the usage of the 3D view functionalities!
Cheers, Larissa (-:
Am 10.02.2020 um 16:55 schrieb Saber Razmjooei:
> Hi Larissa,
> I was clipping the Boulder data to something manageable. But if you
> have moved to NY data, that should be fine too.
> In terms of the underlying terrain, we have a separate blog post.
> https://www.lutraconsulting.co.uk/blog/2018/03/01/working-with-qgis-3d-part-1/
> Usually the z-scales in terrain and buildings do not line up nicely,
> therefore I thought it is better to have 2 different sections: one on
> terrain (rasters) and one on buildings (vector).
> Let me know if you have any questions.
> Kind regards
> Saber
> On Mon, 10 Feb 2020 at 15:38, Larissa Junek <l.junek at gmx.net
> <mailto:l.junek at gmx.net>> wrote:
> Hi Saber,
> I switched the location and prepared a geopackage with the 3D data
> of new york.
> I think your blog should be updated as I still only can depict a
> flat plane of the data in the 3d view tool.
> Sorry for bothering but it's my task to write about the 3D
> settings in QGIS 3.10 ...
> Cheers, Larissa
> Am 10.02.2020 um 15:17 schrieb Larissa Junek:
>> Hi Saber,
>> thanks for giving me the hint. Do I need to add a raster layer
>> with height information like geoTiff (SRTM data etc.)
>> in order to define the position of the 3D buildings ? I got this
>> information in a presentation on youtube. Right now, after
>> defining the single symbol of walls and roofs (data city of
>> Boulder), there is only a plane :-(
>> Cheers Larissa
>> Am 08.02.2020 um 13:38 schrieb Saber Razmjooei:
>>> Hi Larissa,
>>> Apologies. Boulder data indeed contain walls and roofs.
>>> To view the data in 3D, you need to go to each layer and open
>>> Properties > 3D view and change the style to Single symbol.
>>> Also, the dataset is very large. It would be easier if you crop
>>> the data to a smaller area.
>>> Regards
>>> Saber
>>> On Sat, 8 Feb 2020 at 12:00, Saber Razmjooei
>>> <mailto:saber.razmjooei at lutraconsulting.co.uk>> wrote:
>>> Hi Larissa,
>>> Many thanks for looking into documenting this.
>>> I had a quick look at the data. It is only the footprint.
>>> So, you can only extrude the data (based on height).
>>> There is a good data source of 3D buildings here:
>>> https://github.com/wonder-sk/3d-spatial-data
>>> And for building in New York, we wrote a blog post here. The
>>> data have z-valuse and should automatically get picked up by
>>> the 3D map view.
>>> https://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-qgis3d/
>>> Feel free to use any of the content from our website in the
>>> documentation.
>>> Kind regards
>>> Saber
>>> On Fri, 7 Feb 2020 at 13:59, Larissa Junek <l.junek at gmx.net
>>> Hello folks,
>>> for documentation purposes I'd like to visualize the 3d
>>> data of the city
>>> of boulder in qgis 3.10 .
>>> https://bouldercolorado.gov/open-data/city-of-boulder-3d-buildings/
>>> Unfortunately qgis crashes when loading the shapefile
>>> into the 3d view.
>>> Also, where do I have access to the z-coordinate so that
>>> there will be a
>>> 3d view. At the moment there is only visible a plane
>>> with the vectors
>>> but no "z-value" in the 3d view application. Extrusion
>>> doesn't help
>>> solute the problem.
>>> There is a hint that these data have something to do
>>> with GeoJSon, so
>>> maybe I have to find another 3d data suitable for using
>>> in the 3D view
>>> application.
>>> Can somebody help?
>>> Cheers, Larissa
>>> Qgis-community-team mailing list for organizing
>>> community resources such as documentation, translation etc..
>>> Qgis-community-team at lists.osgeo.org
>>> <mailto:Qgis-community-team at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/qgis-community-team
>>> Saber Razmjooei
>>> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk>
>>> +44 (0)7568 129733
>>> Saber Razmjooei
>>> +44 (0)7568 129733
> Saber Razmjooei
> +44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20200213/cf87aa3e/attachment-0001.html>
Qgis-community-team mailing list for organizing community resources such as documentation, translation etc..
