[GeoNode-devel] Thumbnails and legend icons not being loaded and download link not working
Ramiz Sami ramizsami95 at gmail.com
Sat Dec 29 08:55:39 PST 2018
Dear Toni,
Thanks for your response. I checked the URL, it corresponds to the Public
URL and is only missing port 8080.
I also tried running python manage.py updatelayers, Following was the
response that I got:
Inspecting the available layers in GeoServer ...
Found 1 layers, starting processing
Loading user configuration
running configuration <ConfigParser.SafeConfigParser instance at
0x7f60b4db8ef0>
Setting language
Loading custom repository mappings from
/home/ubuntu/Envs/geonode/src/geonode/geonode/catalogue/backends/pycsw_local_mappings.py
Loading outputschemas
Setting MaxRecordDefault
Querying repository with ids: 715d1bb2-0b72-11e9-99f5-0a80530f2042
Request processed
Writing response.
... Creating Thumbnail for Layer [geonode:Hospitals]
Error when generating the thumbnail for resource 1.
Check permissions for file
thumbs/layer-715d1bb2-0b72-11e9-99f5-0a80530f2042-thumb.png.
0x7f60b3390320>
Setting language
Request processed
Writing response.
[updated] Layer Hospitals (1/1)
Finished processing 1 layers in 10.0 seconds.
0 Created layers
1 Updated layers
0 Failed layers
10.000000 seconds per layer
But this didn't solve the issue and these image links are still not
working. The site is live and you can check the layers on
http://ec2-13-229-139-226.ap-southeast-1.compute.amazonaws.com/layers/?limit=20&offset=0.
Can you please check and let me know if you can find what could be the
possible issue?
Best regards,
Syed Ramiz Sami
On Sat, Dec 29, 2018 at 9:44 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear Ramiz,
> I don´t think this is caused by tomat port (8080). The thumb should be
> loaded
> from your static dir. See f.e.
> http://master.demo.geonode.org/uploaded/thumbs/layer-ee9c59ba-09e9-11e9-bb24-0242ac120008-thumb.png
> More likely the URL is not correct? Can you check if it corresponding with
> your public URL?
> Unfortuantely It´s not easy to say what settings is wrong without having a
> look.
> But two things you can try which should help:
> 1) run python manage.py updatelayers
> This recreates your thumbs with correct URL (taken from settings or
> local_settings, clear Browser Cache!)
> 2) Enable geonode updateip as shown here:
> https://lists.osgeo.org/pipermail/geonode-users/2018-November/005158.html
> This should fix your domain settings.
> Happy new !
> – Toni
> >   1. Thumbnails and legend icons not being loaded and download
> >      link not working (Ramiz Sami)
> > Message: 1
> > Date: Sat, 29 Dec 2018 21:29:53 +0500
> > From: Ramiz Sami <ramizsami95 at gmail.com>
> > To: geonode-devel at lists.osgeo.org
> > Subject: [GeoNode-devel] Thumbnails and legend icons not being loaded
> > Message-ID:
> >       <CAApJ-gpQqWU8CJKB-8PmM21g4Y=
> zuQ1DVpepuRVznypsxR2Q_g at mail.gmail.com>
> > Content-Type: text/plain; charset="utf-8"
> > I have deployed Geonode on an AWS EC2 instance using
> http://docs.geonode.org/en/master/tutorials/install_and_admin/geonode_install/index.html#geonode-install
> > <#>. Everything so far is working fine but I am facing an issue.
> > The URL of legend icons are not working on the layer details page. Like
> you
> > can see in the image below:
> > [image: image.png]
> > Same is the case with thumbnail on layers listing page. The thumbnail is
> > not loading like in the image below:
> > [image: image.png]
> > The issue in both the cases is that it produces right URL but skips the
> > port (8080) for Geoserver due to which I end up getting error 404. I have
> > changed the GEOSERVER_PUBLIC_PORT variable in local_settings.py to 8080
> and
> > have verified that the GEOSERVER_PUBLIC_LOCATION variable has correct
> value
> > but it still skips 8080 in that part.
> > Similarly, I get the wrong URL (without port 8080) when I try to download
> > any dataset.
> > Can anyone please tell me where I am going wrong? I couldn't find a clue
> in
> > the documentation.
> > Best regards,
> > Syed Ramiz Sami
> > -------------- next part --------------
> > An HTML attachment was scrubbed...
> > URL: <
> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181229/585a8d76/attachment.html
> > A non-text attachment was scrubbed...
> > Type: image/png
> > Desc: not available
> > URL: <
> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181229/585a8d76/attachment.png
> > Type: image/png
> > Desc: not available
> > URL: <
> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181229/585a8d76/attachment-0001.png
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20181229/3af7a801/attachment.html>
More information about the geonode-devel mailing list
