[OpenLayers-Dev] Github or Trac?
Bart van den Eijnden bartvde at opengeo.org
Wed May 23 04:52:36 EDT 2012
I've made the necessary changes to the Trac pages (of course I could have missed some, but the main pages are done).
I've also made Trac read-only (i.e. removed the permissions TICKET_CREATE, TICKET_APPEND, TICKET_MODIFY and TICKET_CHGPROP) from the authenticated group (and the openlayers user/group, not sure if that was still being used).
I will send out an announcement soon to the user mailing list. I will encourage people who care about their ticket to create a new one in the github issue tracker.
Let me know if you have any concerns.
Also, one thing I'd like to discuss for the future is if we have plans to migrate the Trac Wiki to the github Wiki. I would be in favor of this.
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Apr 29, 2012, at 2:41 PM, Eric Lemoine wrote:
> On Sunday, April 29, 2012, Christopher Schmidt wrote:
> Hi,
> Since the switch to Github, it appears that the OpenLayers project
> now uses two different mechanisms to manage incoming issues and
> tickets: Trac and Github issues.
> Right now, the project appears to have a number of pages directing
> new users to file tickets in trac, such as:
>  http://trac.osgeo.org/openlayers/wiki/FilingTickets
>  http://trac.osgeo.org/openlayers/wiki/FrequentlyAskedQuestions#SVN
>  http://trac.openlayers.org/ being linked as 'support and development'
>  from the homepage.
> It appears that new tickets are being created by users in trac at a
> rate of about 2 per week -- 20 issues created in the past 8 weeks, and
> 741 open tickets, 43 awaiting review.
> In github, there are 109 open issues. Approximately 10 new issues are
> being created per week (40 in the last 18 days). The only obvious
> reference to Github anywhere in the OpenLayers project is a single 'Fork
> us on GitHub' link. (There are a couple other links in the trac wiki,
> but they're hidden relatively well, compared to the 'how to file a bug',
> and don't make it clear that tickets should be filed on github.)
> It looks like the question of where tickets should be made has been
> asked before on the mailing list, with no answer:
>  http://lists.osgeo.org/pipermail/openlayers-dev/2012-January/008345.html
> It was also informally discussed prior to that:
>  http://lists.osgeo.org/pipermail/openlayers-dev/2011-October/008137.html
> but it isn't obvious that any decision was made from that discussion;
> I don't see any discussion of what actions would need to be taken
> in order to shift development to the Github issue tracker (like, for
> example, updating our webpage to direct people there instead of to trac
> when filing new issues).
> It seems that developers are now closing trac tickets as duplicates of
> unsolved Github issues:
>  https://github.com/openlayers/openlayers/issues/392
>  http://trac.osgeo.org/openlayers/ticket/3649
> In the past, I might have requested a vote, but it seems like a vote is
> really not even a plausible approach to the question at this point:
> what's done is done. If developers can confirm that OpenLayers is
> intending all future development to take place using the Github issue
> tracker, and that the trac issue tracker is now a dead end, then it
> would probably be best for new developers if a plan could be developed
> to help migrate the existing trac system into Github, starting with
> migrating links for development moving to Github instead of Trac as the
> recommended source.
> I look forward to any feedback from the active developers on how
> development is intended to work :)
> Thanks for bringing this up Chris.
> I'm in favour of using one issue tracker only, and I was planning to raise the issue after 2.12 final is out.
> I'd like to use GitHub only. In this way we can easily cross-refence between issues, pull requests, commit messages, and review comments. Tracking is so important!
> I was a bit hesitant when I started the release process, because our release procedure relied on ticket fields, such as “version”, that GitHub does not offer. GitHub issues just have a “milestone” and “tags”.
> Since then I've started rewriting the release procedure [*], and I now think we can get by with what GitHub offers.
> Cheers,
> [*] <http://trac.osgeo.org/openlayers/wiki/Release/Procedure>
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Dev mailing list
> Dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20120523/98aa6625/attachment.html
More information about the Dev mailing list
