[postgis-tickets] [PostGIS] #2396: liblwgeom CUnit and PostgreSQL tests fail on big-endian architectures.
trac at osgeo.org
Tue Oct 1 14:18:43 PDT 2013
Reporter: mnencia | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.1.1
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Comment(by robe):
my feeling (and I think pramsey agrees) is that #2084 is unlikely an
endian issue, but might have something to do with architecture that you
are catching and we are missing in caching logic. If you can run by
reversing the tests as he says and provide the output would help diagnose
if its a caching bug. You can also test with one row instead of two and
see if the singleton answer is the same as the table answer.
I guess the fact all are running with the same GEOS might suggest that
GEOS may not be the problem. Although there have been a few fixes in
latest GEOS versions that are platform specific. Can't remember what they
are offhand but I think more likely than an endian issue.
Any chance you can run with the latest 3.3 release. GEOS 3.3.3 is pretty
old. GEOS 3.3.9 is latest of released GEOS 3.3 stable.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2396#comment:35>
