[postgis-tickets] [PostGIS] #3176: Add ST_MinimumRectangle
trac at osgeo.org
Wed Jul 1 12:37:37 PDT 2015
Reporter: mwtoews | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS Future
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Comment (by nw):
I think the following works. I think but haven't proved that a side of a
minimum rectangle must contain one of the sides of the convex hull of the
point geometries. So this algorithm iterates through those sides and
rotates
the hull to be parallel to the y axis, calculates a bounding box, and
counter
rotates it. This gives a number of candidate rectangles, from which I
choose
the smallest, then the "first" based on the sides counting out from the
first
point in the case of ties.
This is just to make the algorithm stable. There
isn't in general a unique minimum rectangle (think of a hexagon). There
could
be other choice mechanisms, since the rectangle chosen (potentially)
depends on
the ordering of the points. The rectangle could alternatively be chosen
based on
the angle of the major side of the rectangle to the X axis, which I think
is
then independent of the point ordering.
This also doesn't handle degenerate rectangles. If the approach seem
sound, once
a rectangle choice method is chosen, I will implement that and take care
of the degenerate cases.
create or replace function ST_MinimumRectangle(g geometry) returns
geometry
language 'plpgsql' as $$
declare
hull geometry;
begin
hull = ST_ExteriorRing(ST_ConvexHull(g));
-- one side must lie along the rectangle.
-- so, for each side, rotate, bbox, counter-rotate bbox
with sides as (
select ST_PointN(hull, n) as a, ST_PointN(hull, n+1) as b,
n as side
from generate_series(1,ST_NPoints(hull)-1) n
angles as (
select side, a, b, st_azimuth(a, b) as angle from sides
boxes as (
select ST_Rotate(ST_Envelope(ST_Rotate(hull,
-angle)),angle) as rect, side, angle from angles
select rect into hull from boxes order by ST_Area(rect), side
limit 1
return hull;
end;
$$ immutable strict;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3176#comment:1>
