[postgis-tickets] [PostGIS] #3201: ST_DistanceSphere uses SRID to obtain spheroid
trac at osgeo.org
Thu Jul 16 23:25:44 PDT 2015
Reporter: mwtoews | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: documentation | Version: trunk
Keywords: |
The manual claims that "[ST_DistanceSphere] currently does not look at the
SRID of a geometry and will always assume its in WGS 84 long lat."
However, since PostGIS 2.0, it does use a valid SRID to get the spheroid.
Compare this, using PostGIS 2.0:
SELECT
ST_Distance_Sphere(p1, p2) AS default,
ST_Distance_Sphere(ST_SetSRID(p1, 4326), ST_SetSRID(p2, 4326)) AS
wgs_84,
ST_Distance_Sphere(ST_SetSRID(p1, 4269), ST_SetSRID(p2, 4269)) AS
grs_1980
FROM (
SELECT ST_MakePoint(0, 0) AS p1, ST_MakePoint(0, 1) AS p2
) f;
-[ RECORD 1 ]--------------
default | 111195.079734632
wgs_84 | 111195.079734632
grs_1980 | 111195.079734022
The distances for unknown SRID and WGS84 are identical. But are different
for GRS80.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3201>
