[postgis-tickets] [PostGIS] #3199: liblwgeom not being installed in postgresql bin (at least not under mingw)
PostGIS trac at osgeo.org
Sat Jul 18 01:26:37 PDT 2015
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 2.2.0
 Component:  loader/dumper  |    Version:  trunk
Resolution:  wontfix        |   Keywords:
Comment (by robe):
 pramsey, strk
 Can you confirm setting --prefix does anything for you.  I did find my
 liblwgeom...dll new friend in /usr/local/bin as you stated (puke)
 However setting the --prefix, doesn't move it and (makes it not install in
 /usr/local/bin anymore) after I run make install. I just get this nice
 friendly message during configure which I think pramsey had put in eons
 ago.
   WARNING: You have set the --prefix to
 '/projects/postgresql/rel/pg9.4w64gcc48/bin'. But we mostly
   ignore the --prefix. For your info, using the values determined from
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3199#comment:5>
