[postgis-tickets] [PostGIS] #3205: missing output for TopoGeo_AddLineString
trac at osgeo.org
Sat Jul 18 01:29:22 PDT 2015
Reporter: remic | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.9
Component: topology | Version: 2.1.x
Resolution: | Keywords:
Description changed by robe:
Old description:
> it seems like the return of TopoGeo_AddLineString
> is missing something.
> here is the script (bottom)
> The error in TopoGeo_AddLineString seems to be ligne 90 94
> "start_node := topology.TopoGeo_AddPoint"
> From what I understood, topogeo_addpoint has the ability to split edges,
> but we don't have any way to get the edge_id of the split edge by
> addpoint.
> I don't see an easy workaround (would need to modify topogeo_addpoint to
> return edge_id, which is a big API change).
> The simplest would be to check before addpoint if the point is going to
> split,
> then if yes save edge_id already existing, addpoint, then look for thhe
> new edge_id resulting from the split.
> There would be worysome cornercase (what if addpoint is used on top of an
> existing node)
> SELECT DropTopology('test_postgis_topology');
> SELECT CreateTopology('test_postgis_topology',0,0.1,false); --2
> DROP TABLE IF EXISTS test_postgis_topology.test_topogeo_linestring ;
> CREATE TABLE test_postgis_topology.test_topogeo_linestring AS
> SELECT 1 AS gid, 'id1' AS id,ST_GeomFromtext('LINESTRING(0 0 , 10 10)',0)
> AS geom
> UNION
> SELECT 2 AS gid, 'id2' AS id, ST_GeomFromtext('LINESTRING(0 10 , 10
> 0)',0) ;
> WITH result_addlinestring AS (
> SELECT id, topology.TopoGeo_AddLineString(
> , geom
> , 0.01) as edge_id
> FROM test_postgis_topology.test_topogeo_linestring
> SELECT count(*) = 4 AS is_TopoGeo_AddLineString_working
> FROM (SELECT DISTINCT * FROM result_addlinestring) AS sub ;
> The function should return 4 different edge_ids, which it does not.
> Hint for workaround : post processing, looking for edge_id that have not
> been returned,
> with surface distance
> SELECT DISTINCT ON (pe.edge_id) edge_id, gid
> FROM problematic_edges AS pe, my_source_lines AS ul
> WHERE ST_DWithin(pe.geom,t,1) = TRUE
> ORDER BY pe.edge_id,
> ST_Area(ST_Intersection(ST_Buffer(pe.geom,1,'quad_segs=2'),ST_Buffer(ul,1,'quad_segs=2')))
> DESC
New description:
addpoint.
split,
existing node)
AS geom
UNION
SELECT 2 AS gid, 'id2' AS id, ST_GeomFromtext('LINESTRING(0 10 , 10 0)',0)
, geom
, 0.01) as edge_id
been returned,
DESC
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3205#comment:2>
