[postgis-tickets] [PostGIS] #3206: winnie crashing with topology ST_AddModeFace in C commit 9.3 w32 bit run
PostGIS trac at osgeo.org
Sat Jul 18 16:19:19 PDT 2015
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  blocker   |  Milestone:  PostGIS 2.2.0
 Component:  topology  |    Version:  trunk
Resolution:            |   Keywords:
Comment (by robe):
 hmm well that did something, but not sure it's good.  Now I'm getting
 failure on SQL/MM
  regress/sqlmm .. failed (diff expected obtained:
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal2.0.0w32/test_4_diff)
 --- regress/sqlmm_expected      2014-08-07 22:32:08 -0400
 /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal2.0.0w32/test_4_out
 2015-07-18 12:23:28 -0400
 @@ -3,21 +3,21 @@
  ERROR:  SQL/MM Spatial exception - null argument
 -1
 -2
 -3
 -4
 -5
 -6
 -ERROR:  SQL/MM Spatial exception - coincident node
 -7
 -8
 +ERROR:  syntax error at or near "d" at character 84
  ERROR:  SQL/MM Spatial exception - not within face
  ERROR:  SQL/MM Spatial exception - invalid point
 http://winnie.postgis.net:1500/job/PostGIS_EDB_regress/2750/consoleFull
 Which seems really odd.  I'll try to see if the 64-bit still works.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3206#comment:7>
