[postgis-tickets] [PostGIS] #2278: make liblwgeom compatible between micro releases
PostGIS trac at osgeo.org
Thu Jul 30 02:58:53 PDT 2015
  Reporter:  mwanner    |      Owner:  strk
      Type:  defect     |     Status:  closed
  Priority:  high       |  Milestone:  PostGIS 2.2.0
 Component:  liblwgeom  |    Version:  2.0.x
Resolution:  fixed      |   Keywords:
Changes (by strk):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 r13855 switches liblwgeom versioning to interface current:revision:age
 model.
 We start with interface 4, of age 2 and revision 0, meaning a numbering of
 2.2.0.
 The interface version is derived from Version.config so there's no
 additional settings to tweak.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2278#comment:14>
