[postgis-tickets] [PostGIS] #3206: winnie crashing with topology ST_AddModeFace in C commit 9.3 w32 bit run
trac at osgeo.org
Fri Jul 31 14:39:33 PDT 2015
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Tom Lane also commented and explained.
http://www.postgresql.org/message-id/15982.1438377791@sss.pgh.pa.us
> Issue is when code like this was introduced
> appendStringInfo(str, "%s%" PRId64, sep, edge->start_node);
> Which uses a PostgreSQL function appendStringInfo - as noted here:
> https://trac.osgeo.org/postgis/ticket/3206
Huh. Apparently, whichever Windows compiler you're using defines
PRId64 as "d", which surely seems pretty broken.
> I noticed a thread in March on pgsql-hackers that discussed int limits
id/20150331141423.GK4878 at alap3.anarazel.de
> in PostgreSQL and Andres Freund made this comment which stuck in my
head:
> " for another we'd need some uglyness to determine the
> correct printf modifier for int64_t (can't use PRId64 etc afaics)."
> What exactly did he mean by can't use PRId64?
That was about the fact that we don't know whether PRId64 is defined
as "ld" or "lld" on machines where either of those could legitimately
mean a 64-bit int. (And while either would work at runtime in that
case, we'd get compiler warnings we don't want if we chose the wrong
one.) That problem doesn't apply to Windows AFAIK.
However, some googling suggests that PRId64 isn't defined on all Windows
build environments, and your report says that there's at least one such
environment where it is defined, but wrongly :-(. So that's yet another
good reason to stay away from PRId64. You'll notice that it appears
nowhere in the Postgres sources.
You did not say how you're declaring the variable that's being printed
here, but if it's based on the int64 type declared by c.h, you should
use the INT64_FORMAT or INT64_MODIFIER strings declared by
c.h/pg_config.h.
regards, tom lane
So aside from my compiler being possibly broken in some way -- does seem
like we should stay away from PRI64. I'm testing using INT64_FORMAT just
replacing for your appendInfoString calls now. My compiler warning went
away and it fixed the sqlmm failure and others. Though I got to check the
other 3 why those are still failing:
Creating database 'postgis_reg'
Loading PostGIS into 'postgis_reg'
Loading Topology into 'postgis_reg'
PostgreSQL 9.4.4 on x86_64-w64-mingw32, compiled by gcc.exe (x86_64-win32
-seh-rev1, Built by MinGW-W64 project) 4.8.3, 64-bit
Postgis 2.2.0dev - r13864 - 2015-07-31 21:35:35
scripts 2.2.0dev r13864
GEOS: 3.5.0dev-CAPI-1.9.0 r4064
PROJ: Rel. 4.9.1, 04 March 2015
Running tests
regress/legacy_validate .. ok
regress/legacy_predicate .. ok
regress/legacy_invalid .. ok
regress/sqlmm .. ok
regress/legacy_query .. ok
regress/addnode .. ok
regress/addedge .. ok
regress/addface .. ok
regress/addface2.5d .. ok
regress/addtopogeometrycolumn .. ok
regress/polygonize .. ok
regress/st_addisoedge .. failed (diff expected obtained:
/projects/postgis/tmp/2.2_pg9.4w64/test_12_diff)
regress/st_addisonode .. ok
regress/st_addedgemodface .. failed (diff expected obtained:
/projects/postgis/tmp/2.2_pg9.4w64/test_14_diff)
regress/st_addedgenewfaces .. failed (diff expected obtained:
/projects/postgis/tmp/2.2_pg9.4w64/test_15_diff)
regress/st_changeedgegeom .. ok
regress/st_createtopogeo .. ok
regress/st_getfacegeometry .. ok
regress/st_getfaceedges .. ok
regress/st_modedgeheal .. ok
regress/st_modedgesplit .. ok
regress/st_newedgeheal .. ok
regress/st_newedgessplit .. ok
regress/st_remedgenewface .. ok
regress/st_remedgemodface .. ok
regress/st_simplify .. ok
regress/topoelement .. ok
regress/topoelementarray_agg .. ok
regress/topogeo_addlinestring .. ok
regress/topogeo_addpoint .. ok
regress/topogeo_addpolygon .. ok
regress/topogeometry_type .. ok
regress/topojson .. ok
regress/topologysummary .. ok
regress/topo2.5d .. ok
regress/totopogeom .. ok
regress/droptopology .. ok
regress/droptopogeometrycolumn .. ok
regress/copytopology .. ok
regress/createtopogeom .. ok
regress/createtopology .. ok
regress/gml .. ok
regress/getnodebypoint .. ok
regress/getedgebypoint .. ok
regress/getfacebypoint .. ok
regress/getringedges .. ok
regress/gettopogeomelements .. ok
regress/layertrigger .. ok
regress/validatetopology .. ok
uninstall .. ok (4336)
Run tests: 50
Failed: 3
Makefile:84: recipe for target `check' failed
make[1]: *** [check] Error 3
make[1]: Leaving directory `/projects/postgis/branches/2.2/topology/test'
Makefile:109: recipe for target `check' failed
make: *** [check] Error 2
might be just parts of the topology code I missed replacing.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3206#comment:31>
