[postgis-tickets] r15297 - Prepare for PostGIS 2.2.5 release
Regina Obe lr at pcorp.us
Sun Jan 29 11:59:27 PST 2017
Author: robe
Date: 2017-01-29 11:59:27 -0800 (Sun, 29 Jan 2017)
New Revision: 15297
   branches/2.2/ChangeLog
   branches/2.2/HOWTO_RELEASE
   branches/2.2/NEWS
   branches/2.2/README.postgis
   branches/2.2/Version.config
   branches/2.2/doc/release_notes.xml
Modified: branches/2.2/ChangeLog
--- branches/2.2/ChangeLog	2017-01-28 08:30:09 UTC (rev 15296)
+++ branches/2.2/ChangeLog	2017-01-29 19:59:27 UTC (rev 15297)
@@ -1,3 +1,28 @@
+2017-01-07 08:59  Regina Obe <lr at pcorp.us>
+	* [r15286] NEWS, postgis/gserialized_gist_2d.c,
+	  regress/knn_recheck.sql, regress/knn_recheck_expected: KNN
+	  recheck in 9.5+ fails with index returned tuples in wrong order
+	  closes #3418 for PostGIS 2.2
+	  add NEWS note for missing GRANT in upgrade
+	  references #3680
+2016-12-20 03:24  Regina Obe <lr at pcorp.us>
+	* [r15279] utils/postgis_proc_upgrade.pl: PostGIS upgrade scripts
+	  missing GRANT for views
+	  closes #3680 for PostGIS 2.2
+	  also correct strk's email
+2016-11-26 21:25  Regina Obe <lr at pcorp.us>
+	* [r15259] Version.config: Bump to 2.2.5dev
+2016-11-26 21:19  Regina Obe <lr at pcorp.us>
+	* [r15257] ChangeLog, NEWS, README.postgis, Version.config,
+	  doc/release_notes.xml: Prep for 2.2.4 release
 2016-11-26 18:54  Regina Obe <lr at pcorp.us>
 	* [r15254] NEWS, raster/rt_pg/rtpostgis.sql.in: add raster
Modified: branches/2.2/HOWTO_RELEASE
--- branches/2.2/HOWTO_RELEASE	2017-01-28 08:30:09 UTC (rev 15296)
+++ branches/2.2/HOWTO_RELEASE	2017-01-29 19:59:27 UTC (rev 15297)
@@ -1,6 +1,6 @@
 How to release
-Date: 2015-10-08
+Date: 2017-01-30
 Versioning Scheme
@@ -25,7 +25,7 @@
 All POSTGIS_MICRO_VERSION that are in branch or trunk should end in dev.
 So for example if you just release 2.1.1, then the 2.1 branch should have
-POSTGIS_MICRO_VERSION set to 2dev so that the full version is 2.1.2dev.
+POSTGIS_MICRO_VERSION set to 2dev so that the full version is 2.2.5dev.
 *Liblwgeom*
@@ -63,8 +63,8 @@
 - Edit README.postgis and set release date and version.
 - Add release notes in doc/release_notes.xml
 - Update Version.config to drop the "dev" suffix
-- Add the "dev" suffixed version in extensions/upgradeable_versions.mk
-  and ensure all the previous released minor versions are listed in it
+- Ensure all the previous released micro versions are listed in
+  in extensions/upgradeable_versions.mk
 - Commit all changes
 - Tag branch:
    $ base=http://svn.osgeo.org/postgis/
@@ -72,6 +72,7 @@
    $ svn copy -m "Tagged release $rev" $base/branches/2.2 $base/tags/$rev
 - Run: sh make_dist.sh $rev (or use debbie for this)
 - Build and test generated tarball (including extension upgrade)
+- Update jenkins jobs to latest micro dev.
 - Copy tarball to web site and edit downloads page
 - Announce on e-mail
     - postgis-users
@@ -89,7 +90,7 @@
        -- http://debbie.postgis.net:8080 (log in)
        Create new job copy last tag e.g. PostGIS_2.0_tagged_docs to PostGIS_2.1_tagged_docs
        and make appropriate edits and then just run.
-       Or just be lazy and bug Regina Obe do this.
+       Or just be lazy and bug Regina Obe to do this.
     - Freshmeat
     - Wikipedia
     - Twitter (we all love twitter don't we)
Modified: branches/2.2/NEWS
--- branches/2.2/NEWS	2017-01-28 08:30:09 UTC (rev 15296)
+++ branches/2.2/NEWS	2017-01-29 19:59:27 UTC (rev 15297)
@@ -1,5 +1,5 @@
 PostGIS 2.2.5
-2017/MM/DD
+2017/01/29
  * Bug Fixes *
  - #3418, KNN recheck in 9.5+ fails with index returned tuples in wrong order
Modified: branches/2.2/README.postgis
--- branches/2.2/README.postgis	2017-01-28 08:30:09 UTC (rev 15296)
+++ branches/2.2/README.postgis	2017-01-29 19:59:27 UTC (rev 15297)
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.2.4
-:Date: 2016-11-26
+:Version: 2.2.5
+:Date: 2017-01-29
 :Website: http://postgis.net
 This distribution contains a module which implements GIS simple features, ties
Modified: branches/2.2/Version.config
--- branches/2.2/Version.config	2017-01-28 08:30:09 UTC (rev 15296)
+++ branches/2.2/Version.config	2017-01-29 19:59:27 UTC (rev 15297)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=5dev
+POSTGIS_MICRO_VERSION=5
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: branches/2.2/doc/release_notes.xml
--- branches/2.2/doc/release_notes.xml	2017-01-28 08:30:09 UTC (rev 15296)
+++ branches/2.2/doc/release_notes.xml	2017-01-29 19:59:27 UTC (rev 15297)
@@ -3,26 +3,36 @@
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
     <sect1>
+      <title>Release 2.2.5</title>
+        <para>Release date: 2017/01/30</para>
+        <para>This is a bug fix and performance improvement release.</para>
+        <simplesect>
+            <title>Bug Fixes and Enhancements</title>
+            <para>3418, KNN recheck in 9.5+ fails with index returned tuples in wrong order</para>
+            <para>3680, PostGIS upgrade scripts missing GRANT for views</para>
+        </simplesect>
+    </sect1>
+    <sect1>
       <title>Release 2.2.4</title>
         <para>Release date: 2016/11/26</para>
-  		  <simplesect>
-  			  <title>Bug Fixes and Enhancements</title>
-						<para>1973, st_concavehull() returns sometimes empty geometry collection
-										Fix from gde</para>
-						<para>3656, Fix upgrade of aggregates from 2.2 or lower version</para>
-						<para>3501, add raster constraint max extent exceeds array size limit
-									for large tables, change to use ST_Extent</para>
-						<para>3659, Crash caused by raster GUC define after CREATE EXTENSION
-							 using wrong memory context. (manaeem)</para>
-  		  </simplesect>
+        <simplesect>
+            <para>1973, st_concavehull() returns sometimes empty geometry collection
+                            Fix from gde</para>
+            <para>3656, Fix upgrade of aggregates from 2.2 or lower version</para>
+            <para>3501, add raster constraint max extent exceeds array size limit
+                        for large tables, change to use ST_Extent</para>
+            <para>3659, Crash caused by raster GUC define after CREATE EXTENSION
+                 using wrong memory context. (manaeem)</para>
+        </simplesect>
     </sect1>
     <sect1>
       <title>Release 2.2.3</title>
         <para>Release date: 2016/10/06</para>
-  		  <simplesect>
+        <simplesect>
             <para>3615, Fix schema support in RT_CreateOveriew (Cait Smith)</para>
             <para>3628, Fix lack of support for capitalized-Y in SwapOrdinates</para>
             <para>3524, Add interruptibility to geography brute-force distance
@@ -55,7 +65,7 @@
             <para>3644, Deadlock on interrupt</para>
             <para>3542, Crash on Geometry(MultiCurve())</para>
             <para>Numerous documentation corrections from ruvyn</para>
-  		  </simplesect>
+        </simplesect>
     </sect1>
     <sect1>
