[postgis-tickets] r17309 - Drop pre-existing db when running without any special mode flags on database handling
Paul Ramsey
pramsey at cleverelephant.ca
Fri Mar 8 03:18:45 PST 2019
Author: pramsey
Date: 2019-03-08 15:18:45 -0800 (Fri, 08 Mar 2019)
New Revision: 17309
trunk/regress/run_test.pl
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2019-03-08 21:51:47 UTC (rev 17308)
+++ trunk/regress/run_test.pl 2019-03-08 23:18:45 UTC (rev 17309)
@@ -235,9 +235,9 @@
else
- print STDERR "Database $DB already exists.\n";
- print STDERR "Drop it, or run with the --nocreate flag to use it.\n";
- exit(1);
+ print STDERR "Database $DB already exists, dropping.\n";
+ `dropdb $DB`;
+ create_spatial();
