[postgis-tickets] r17310 - Cost a few more opreators
Paul Ramsey
pramsey at cleverelephant.ca
Fri Mar 8 03:35:12 PST 2019
Author: pramsey
Date: 2019-03-08 15:35:12 -0800 (Fri, 08 Mar 2019)
New Revision: 17310
trunk/postgis/postgis.sql.in
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2019-03-08 23:18:45 UTC (rev 17309)
+++ trunk/postgis/postgis.sql.in 2019-03-08 23:35:12 UTC (rev 17310)
@@ -552,7 +552,8 @@
CREATE OR REPLACE FUNCTION geometry_overlaps(geom1 geometry, geom2 geometry)
RETURNS boolean
AS 'MODULE_PATHNAME' ,'gserialized_overlaps_2d'
- LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL;
+ LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
+ _COST_LOW;
-- Availability: 0.1.0
-- Changed: 2.0.0 use gserialized selectivity estimators
@@ -567,7 +568,8 @@
CREATE OR REPLACE FUNCTION geometry_same(geom1 geometry, geom2 geometry)
RETURNS boolean
AS 'MODULE_PATHNAME' ,'gserialized_same_2d'
+ _COST_LOW;
CREATE OPERATOR ~= (
@@ -582,7 +584,8 @@
CREATE OR REPLACE FUNCTION geometry_distance_centroid(geom1 geometry, geom2 geometry)
RETURNS float8
AS 'MODULE_PATHNAME', 'ST_Distance'
+ _COST_MEDIUM;
-- Availability: 2.0.0
CREATE OR REPLACE FUNCTION geometry_distance_box(geom1 geometry, geom2 geometry)
