[postgis-tickets] r17336 - Fix typos in doc release and update change log
Regina Obe lr at pcorp.us
Mon Mar 11 12:39:51 PDT 2019
Author: robe
Date: 2019-03-11 12:39:51 -0700 (Mon, 11 Mar 2019)
New Revision: 17336
   branches/2.3/ChangeLog
   branches/2.3/doc/release_notes.xml
Modified: branches/2.3/ChangeLog
--- branches/2.3/ChangeLog	2019-03-11 19:24:16 UTC (rev 17335)
+++ branches/2.3/ChangeLog	2019-03-11 19:39:51 UTC (rev 17336)
@@ -1,3 +1,95 @@
+2019-02-15 19:00  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17257] Update test running instructions
+2019-02-15 18:54  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17255] Update OGC certification scripts to match SFSQL 1.2
+	  signatures
+2019-02-11 17:34  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17241] Add generated file
+	* [r17240] Add initialization to lexer
+	  References #4017
+2019-01-22 09:02  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17204] Revert r17178
+	  It changes the behaviour of _postgis_pgsql_version
+	  References #4303
+2019-01-18 21:56  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17188] Un space
+2019-01-18 18:05  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17184] Geodetic tolerance issue in 32-bit
+	  References #4298
+2019-01-18 17:24  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17178] Use `server_version_num` instead of parsing `version()`
+	  References #4296
+2019-01-18 16:07  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17177] Avoid passing a NULL pointer to GEOSisEmpty
+	  Closes #4275
+	  Closes https://github.com/postgis/postgis/pull/362
+2019-01-11 21:45  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17140] More robust geography distance
+	  References #4290
+2018-12-26 04:12  Regina Obe <lr at pcorp.us>
+	* [r17121] Fix so custom --with-projdir= configure switch works
+	  again.
+	  Closes #4279 for PostGIS 2.3
+2018-12-17 10:39  Darafei Praliaskouski <me at komzpa.net>
+	* [r17111] Support Proj 6. Support is via legacy API.
+	  Closes #4254
+	  Closes https://github.com/postgis/postgis/pull/354
+2018-11-27 00:16  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17080] Change test conditions to explicit empty test
+	  References #4245
+2018-11-25 19:36  Darafei Praliaskouski <me at komzpa.net>
+	* [r17076] Stabilize GiST ND indexes for mixed dimensions
+	  Patch by Darafei Praliaskouski
+	  Thanks to
+	  Arthur Lesuisse for synthesizing test case,
+	  Andrew Gierth for finding runaway memcpy,
+	  Raúl Marín for pointing to memory problem in index construction.
+	  Closes #4139
+2018-11-24 05:08  Regina Obe <lr at pcorp.us>
+	* [r17066] Flip to 2.3.9dev
+2018-11-24 05:02  Regina Obe <lr at pcorp.us>
+	* [r17064] Preparing for 2.3.8 release
 2018-11-22 16:14  Raúl Marín Rodríguez <rmrodriguez at carto.com>
 	* [r17056] Avoid unaligned memory access in BOX2D_out
Modified: branches/2.3/doc/release_notes.xml
--- branches/2.3/doc/release_notes.xml	2019-03-11 19:24:16 UTC (rev 17335)
+++ branches/2.3/doc/release_notes.xml	2019-03-11 19:39:51 UTC (rev 17336)
@@ -3,8 +3,8 @@
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
     <sect1>
-      <title>Release 2.3.8</title>
-      <para>Release date: 2018/11/24</para>
+      <title>Release 2.3.9</title>
+      <para>Release date: 2019/03/10</para>
       <para>This is a bug fix and performance improvement release.</para>
       <simplesect>
           <title>Bug Fixes and Enhancements</title>
