[postgis-tickets] [PostGIS] #4349: "make check" should detect which PostgreSQL instance to use from pg_config - Part 2
PostGIS trac at osgeo.org
Tue Mar 12 20:52:03 PDT 2019
- Part 2
 Reporter:  bowguy   |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 From https://trac.osgeo.org/postgis/ticket/186
 'Currently "make check" requires createdb, psql, and dropdb to be on the
 user's path. If more than one instance of PostgreSQL has been installed on
 a system this is problematic.
 configure already detected which PostgreSQL instance to build against ...
 why not prefix the binaries with BINDIR found in pg_config rather than
 relying on what may or may not exist in one's PATH.'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4349>
