[postgis-tickets] [PostGIS] #4287: Assertion failure in gserialized_gist_picksplit while creating gist index on geometry(LineString, 4326) column
PostGIS trac at osgeo.org
Mon Mar 11 13:55:08 PDT 2019
on geometry(LineString,4326) column
  Reporter:  bgandhi1  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.5.3
 Component:  postgis   |    Version:  2.4.x
Resolution:            |   Keywords:
Comment (by pramsey):
 No, not able to reproduct.
 postgis24=# \d t
                               Table "public.t"
     Column     |           Type            | Collation | Nullable |
 Default
  surface_bh_ls | geometry(LineString,4326) |           |          |
 postgis24=# create index t_surface_bh_ls_x on t using gist(surface_bh_ls);
 CREATE INDEX
 postgis24=# select postgis_full_version();
 NOTICE:  Function postgis_gdal_version() not found.  Is raster support
 enabled and rtpostgis.sql installed?
 NOTICE:  Function postgis_raster_scripts_installed() not found. Is raster
 support enabled and rtpostgis.sql installed?
 NOTICE:  Function postgis_raster_lib_version() not found. Is raster
  POSTGIS="2.4.8dev r17331" PGSQL="100" GEOS="3.8.0dev-CAPI-1.11.0
 8d02a094" PROJ="Rel. 6.0.0, March 1st, 2019" LIBXML="2.9.4" LIBJSON="0.13"
 LIBPROTOBUF="1.3.1"
 (1 row)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4287#comment:5>
