[postgis-tickets] [PostGIS] #4287: Assertion failure in gserialized_gist_picksplit while creating gist index on geometry(LineString, 4326) column
PostGIS trac at osgeo.org
Mon Mar 11 14:00:55 PDT 2019
on geometry(LineString,4326) column
  Reporter:  bgandhi1  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 2.5.3
 Component:  postgis   |    Version:  2.4.x
Resolution:            |   Keywords:
Comment (by pramsey):
 However, the source of the problem is likely the Nan-valued vertices in
 the data? Do you know how you got those?
 SELECT ST_AsText(surface_bh_ls)
 FROM t
 WHERE st_x(st_endpoint(surface_bh_ls)) =  double precision 'NaN';
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4287#comment:6>
