[postgis-tickets] [PostGIS] #4349: "make check" should detect which PostgreSQL instance to use from pg_config - Part 2
PostGIS trac at osgeo.org
Tue Mar 12 20:59:11 PDT 2019
- Part 2
  Reporter:  bowguy   |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by bowguy):
 I ran this on Debian and worked fine.  I added the code for MingW but did
 not test that.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4349#comment:1>
