[postgis-tickets] [PostGIS] #4349: "make check" should detect which PostgreSQL instance to use from pg_config - Part 2
trac at osgeo.org
Wed Mar 13 00:56:34 PDT 2019
- Part 2
Reporter: bowguy | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"17339" 17339]:
#!CommitTicketReference repository="" revision="17339"
Ensure "make check" uses configured PostgreSQL target bins
Closes #4349
Patch by Bruce Rindahl
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4349#comment:2>
