[postgis-tickets] [PostGIS] #4349: "make check" should detect which PostgreSQL instance to use from pg_config - Part 2
trac at osgeo.org
Wed Mar 13 08:10:31 PDT 2019
- Part 2
Reporter: bowguy | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment (by strk):
In [changeset:"17340" 17340]:
#!CommitTicketReference repository="" revision="17340"
Ensure "make check" uses configured PostgreSQL target bins under regress
too
References #4349
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4349#comment:3>
