[postgis-tickets] r17348 - Raster is not required anymore for extension support (hurra!)
Sandro Santilli strk at kbt.io
Wed Mar 20 09:03:00 PDT 2019
Author: strk
Date: 2019-03-20 09:03:00 -0700 (Wed, 20 Mar 2019)
New Revision: 17348
   trunk/README.postgis
Modified: trunk/README.postgis
--- trunk/README.postgis	2019-03-20 16:00:28 UTC (rev 17347)
+++ trunk/README.postgis	2019-03-20 16:03:00 UTC (rev 17348)
@@ -78,8 +78,8 @@
 * GDAL (Optional, Version 1.8.0 or higher 1.9+ is strongly recommended)
   GDAL (http://gdal.org) is *required* if you want to compile PostGIS
-  with raster or extension support. To compile without raster support you
-  must ``./configure --without-raster`` (also disables extension)
+  with raster support. To compile without raster support you
+  must ``./configure --without-raster``
 * CGAL 4.1+ and SFCGAL 1.3.1+ (Optional) needed for advanced 3D support
