[postgis-tickets] [PostGIS] #4353: Backend crash using ST_Buffer
trac at osgeo.org
Wed Mar 20 09:40:40 PDT 2019
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
It looks like someone changed the API of a C function, resulting in a
backend crash upon using ST_Buffer old signature:
==8887== Invalid read of size 1
==8887== at 0x5442B0: pg_detoast_datum (in
/usr/lib/postgresql/9.6/bin/postgres)
==8887== by 0x19D7D2A6: buffer (lwgeom_geos.c:809)
==8887== Address 0x0 is not stack'd, malloc'd or (recently) free'd
NOTE: I'm using old signature because upgrade fails (see #4353)
Signature was changed in r17300 so Paul: it is in your plate to fix!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4353>
